Hello - I have a client that has 2 network seats... 1 for AutoCAD and 1 for BDSP -
LM Tools says the 1 BDSP is in use. No one has it open. I had them check both computers that has it installed... No one has borrowed it.
I had them open software on their computers to use the licenses... And showed all license being used - then I had them get out of everything - and it still says the 1 BDSP license is being used...
How can we get it to return the license?
LD
Solved by DarrenP. Go to Solution.
try to stop/start the license manager
DarrenP
Well - that did it!
They have access to all their seats and are working..
Thanks!
LD
The easiest ones are often the best.
If this continues to be a problem, consider using the TIMEOUTALL option in an adsfklex.opt file. That should automatically release a stuck license.
Good Luck!
