Installation & Licensing
How to unlock a network seat?
3 REPLIES 3
LisaDrago
234 Views, 3 Replies
Hello - I have a client that has 2 network seats... 1 for AutoCAD and 1 for BDSP -
LM Tools says the 1 BDSP is in use. No one has it open. I had them check both computers that has it installed... No one has borrowed it.
I had them open software on their computers to use the licenses... And showed all license being used - then I had them get out of everything - and it still says the 1 BDSP license is being used...
How can we get it to return the license?
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
3 REPLIES 3
DarrenP
in reply to: LisaDrago
try to stop/start the license manager
DarrenP
LisaDrago
in reply to: DarrenP
Well - that did it!
They have access to all their seats and are working..
Thanks!
LD
TravisNave
The easiest ones are often the best.
If this continues to be a problem, consider using the TIMEOUTALL option in an adsfklex.opt file.  That should automatically release a stuck license.
Good Luck!
Autodesk Forums:
Administrator Productivity
