Hi All
I know there is a manual way to turn off DAP in the Autodesk 2015 applications but ...being a lage organisation with thousands of desktops this is not feasible. I am looking for a way to do this using either the administrative image/modifying the .ini file or a registry hack.
Looking forward to suggestions from the community.
Much appreciated.
Msharif
These may help,
http://www.harrycaskey.com/disable-autodesk-customer-involvement-program-cip/
Thank you for taking part in our community!
Hi David
Thank you for your reply, I have been through both of these sites, I can automate disabling the CIP but have not found a way of automating the Desktop Analytics Program. Isn't there a registry hack or an application change in the deployment tool or a change in the .ini file which will remove it?
regards
MSharif
I was able to accomplish this by editing the Default User registry. That being said, you can apply it via GPO.
For me, I do these tweaks when creating OS deployments with Autodesk software for SCCM.
[HKEY_CURRENT_USER\Software\Autodesk\MC3]
"ADAOptIn"=dword:00000000
Turn off desktop analytics. Type desktopanalytics in the command line and deselect yes. Problem solved.
