Installation & Licensing
How to install autocad with a network license
3 REPLIES 3
mbach
1150 Views, 3 Replies
I cant find any guide on how to install a network licensed autocad.
Can someone please help?
3 REPLIES 3
DarrenP
in reply to: mbach
how to set up license manager: http://forums.autodesk.com/t5/Installation-Licensing/Quick-Start-Guide-for-Configuring-LMTOOLS/td-p/...
DarrenP
mbach
in reply to: DarrenP
I have gone through the guide, but for some reason when I start autocad it cant find the FlexNet Licence server manager. I then enter the computer name but it gives me a Licensing error; "A valid license could not be optained by network license manager" 😞
when I install autocad I installed it as a single network license version.. this is correct ?
TravisNave
in reply to: mbach
If your license server is running and your server status shows that, then it is probably a firewall issue.  You need to allow ports 2080 and 27000 and all four .exe files.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
