Installation & Licensing
how to get activation code using my prouct key and serial no
27 REPLIES 27
Message 1 of 28
vnrvjiet
17004 Views, 27 Replies
Sir,
We have registered autocad2010 32 bit already with autodesk ,but we are unable to get the activation code.
Please help us
Our product key 001B1
serial No:xxx-xxxxxxxx
Edited by
Discussion_Admin
Tags (2)
27 REPLIES 27
Message 2 of 28
Patchy
in reply to: vnrvjiet
You should not post everything about your account.
Message 3 of 28
TravisNave
Please call Autodesk Product Registration and Authorization:
http://en.autodesk.ca/adsk/servlet/index?siteID=9719649&id=9830778
1-800-551-1490 > Option 1 (English) > Option 1 > (Stand-alone)
Asia / Pacific: 65.6735.5688
Europe / Middle East / Asia: 41.32.723.9595
You will need to provide your serial number and the request code.
Autodesk Forums:
Message 4 of 28
Message 5 of 28
I want you to help me generate activation code
my product key 001D1
serial no: xxx-xxxxxxxx
Message 6 of 28
simona.golisciano
Hi teejay7,
Welcome on our forums.
For confidentiality reasons, serial numbers should not be published on the forums, that's why I edited your post. Regarding your activation issue, I'll send you a Private Message shortly.
Regards
Simona Golisciano
Message 7 of 28
im unable to activate my auto cad 2010 as the serial number i put it says is not prpoper but i have installed it using the same serial number...wot should i do to activate it.
Message 8 of 28
camilo.lemos
Hi farheen1691,
Please, send me your serial number and request code via Private Message (click on my camilo.lemos profile name and then on Send This User a Private Message).
I will help you with this activation.
Camilo Lemos
Message 9 of 28
9777916645
i installed autocad 2010 64bit,and the product key -462B1
NW hw can i get that activation no.
Message 10 of 28
I want serial number of product key 001D1
Message 11 of 28
Kindly assist me on how to activate autocad 2010, my email is xxxxx.com.
Message 12 of 28
joane.bonghanoy
in reply to: yemiight
Hi Folorunso.
I had to edit your post and removed your email address. Moving forward for your security and privacy, please avoid posting any personal information nor License details.
Regarding your issue with Activation, what is the error message? Have you checked some FAQs and troubleshooting steps from this link?
For future reference, note that you can also contact our Registration and Activation team directly for any Activation issues through here
Joane Bonghanoy
Message 13 of 28
I have a very similar issue and am awaiting a reply from the Autodesk team, but was hoping someone on here could help me out. I have 5 copies of AutoCAD LT 2012 that need migrating, but none of them are working. We are a local UK council and have very specific needs for our proxy settings to not be violated. Could someone either help get Tech support reply to me or help me get my licences transferred?
Many Thanks!
Dave
Message 14 of 28
camilo.lemos
in reply to: yankeedave
Hi @yankeedave and welcome to the Community!
Your screenshot is for AutoCAD 2013, while your post mentions LT 2012. That could well be the issue with the license transfer as your serial number for LT 2012 and 2013 will be different.
Could you please double check the product licensing information and try again?
If that doesn't work, please, send me your serial number and request code via Private Message (click on my camilo.lemos profile name and then on Send This User a Private Message) and I'll look into this for you.
Thanks!
Camilo Lemos
Message 15 of 28
i can't take an activation code could you please send me an activation code for auto cad 2010?
best regards.
Message 16 of 28
joane.bonghanoy
Hi @farhad_khan1411,
You can do an Online Activation via these steps.
If you need further assistance, feel free to contact the Activation and Registration team directly:
1.            Visit http://knowledge.autodesk.com/contactus
2.            Select “Activation & Registration” or “License Management”
3.            Select appropriate subtopics from the pull-down menus
4.            Select “I Still Need Help”  if you need personal assistance
Joane Bonghanoy
Message 17 of 28
yankeedave
in reply to: camilo.lemos
Thanks for all the help Camilo!
I have another machine that I am having issues getting the machine to connect to verify the serial number. Could someone please help me out with it? It is for AutoCAD LT 2015.
Thanks!
Dave
Message 19 of 28
2010 serial number xxx-xxxxxxxxx, request code- 89AE XJD9 9WYF CT7R G4XG 6A6N S4CX 2H3Z....
Please help me activation code..
Best regds.
Edit: removed serial number
Message 20 of 28
matthew.d
Hi @Anonymous,
Welcome to the community!
Sorry to hear about the issue. The serial number you have provided is not a valid serial number, where did you receive it from?
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
Administrator Productivity
