Installation & Licensing
how to get a standalone license from a server license
2 REPLIES 2
bbhn_longchamp
283 Views, 2 Replies
HI there,
I own a AutocadCAD Map 2013 which works with a server license. This computer in not in the network anymore. How can I still use AutoCAD ? Is there a way to transform my server license to an standalone one ? If yes, how can I do it ?
Tank'y in advance for your answer
R.Longchamp
2 REPLIES 2
Hi R.Longchamp and welcome to the forums!
Changes from Network to Standalone licensing are made directly by our resellers. Please, contact your authorized Autodesk reseller and ask them about the procedures to perform this change.
Thank you,
Camilo Lemos
TravisNave
in reply to: bbhn_longchamp
I believe the customer wants to get a new license file for a replacement server.  You can do this thru your Reseller or thru the Autodesk Activations department.
You can use the online method to activate your license here:
http://usa.autodesk.com/adsk/servlet/pc/item?id=18424632&siteID=123112
Or you can can call Autodesk Product Registration and Authorization:
http://en.autodesk.ca/adsk/servlet/index?siteID=9719649&id=9830778
1-800-551-1490 > Option 1 (English) > Option 2 > (Network)
You will need to provide your serial number and ethernet ID of the new license server.
www.licenseparser.com > This will break down your current license file into plain english and you will find the serial number there.
For a Quick-Start Guide on configuring the Autodesk License Manager, please see my post for further information:
http://forums.autodesk.com/t5/Installation-Licensing/Quick-Start-Guide-for-Configuring-LMTOOLS/m-p/3...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
