Installation & Licensing
Product Support
hashim.mundol
Message 1 of 2 (236 Views)
How to combine Autodesk products with non-Autodesk products
236 Views, 1 Replies
07-15-2011 06:37 AM
 Question:
more then 1 applications using LMTools
Hello, We use multiple products that all use the LMTools utility.
For example on one server: Ansys, Autocad and Mathcad. We have the
feeling that different license servers are in the way of each other.
Do you have any experiance with this? What do you advise if we got
Answer:
http://usa.autodesk.com/getdoc/id=TS13541551
http://usa.autodesk.com/getdoc/id=TS67745
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
TravisNave
Message 2 of 2 (227 Views)
Re: How to combine Autodesk products with non-Autodesk products
07-15-2011 09:46 AM in reply to: hashim.mundol
There are better ways to go about combining licensing of different products.  In your example, you are pointing to two different LMGRD.EXE files.  I do not recommend this as running two different license manager files with potentially different versions can cause issues.
The Flexnet License Manger is backwards compatible.  Using the latest version is always recommended.  Combining the use of the NLM with multiple 3rd parties can be accomplished with one LMGRD.EXE file so long as the respective vendor files (i.e. adksflex.exe and sgiawd.exe) are also present in the same directly location.
Therefore to combine adksflex and sgiawd files, you would only need one location located at:
C:\Program Files\Autodesk Network License Manager
with the following files:
lmgrd.exe
lmtools.exe
lmutil.exe
adskflex.exe
sgiawd.exe
You would still create a separate service for each vendor but the paths would point to the same LMGRD.EXE file.
In fact, as I was writing this a customer needed this done.  I was able to combine Autodesk, Alias, Soliworks, ProE, and Keystone all into one folder with one LMGRD.EXE and all the vendor files, configured with one LMTOOLS... all the latest version 11.9.1.
You can also combine the .LIC files so long as the headers are the same, just as you would normally combine Autodesk products.  Just include the VENDOR and PORT lines as necessary.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
