Installation & Licensing
How to Change Serial Number
1 REPLY 1
gtdobson
730 Views, 1 Reply
I installed a copy of Inventor 2010 on two machines (my laptop and my
workstation) with the intent of moving the license between the two. I
found this to be a little inconvenient for my work, so I purchased an additional
copy of Inventor.
The problem is that I can not figure out how to change the serial number
on my workstation to the new one. The standard License Manager is expecting
me to import the licese that was exported to my laptop.
Do I need to uninstall and then reinstall the software?
1 REPLY 1
TravisNave
in reply to: gtdobson
The End User License Agreement (EULA) allows for a second activation of your software for the purpose that you are speaking. You are allowed to install and activate a single license on your workstation as well as your laptop. There is no need to transfer the licenses between the two. Simply activate both. If the license will not activate, call Autodesk at 1-800-551-1490 and ask for an Activation Code.
3.1.2 Use Away from Usual Work Location.
(a) For Stand-alone (Individual) and Multiseat Stand-alone Versions. If You have acquired a Stand-alone (Individual) Version or Multiseat Stand-alone Versions, for each Permitted Number of copies of the Software, You may Install and Access, solely within Your Territory, one (1) additional copy of the Software on a second Computer provided that:
(i) such second Computer is owned or leased by You (and not by another person, such as Your employee, if any);
(ii) such second Computer is either a portable Computer or a nonserver Computer away from Your usual work location;
(iii) the additional copy of Software is Accessed solely for the purpose of enabling You (or Your employee, if any) to perform work while away from Your usual work location;
(iv) the original and additional copy of the Software are used only by the same person, and only one (1) of the Software copies is Accessed at any one time; and
(v) both copies of the Software are Installed and Accessed exclusively with the copy protection device (if any) supplied with the Software.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
