Installation & Licensing
How do I request a newtork license?
4 REPLIES 4
376 Views, 4 Replies
We use several Autodesk products, (AutoCAD, 3DSMax, Maya, Inventor, Revit) at my company and have always used network licenses.
The old  www.autodesk.com/licensesupport links don't work, the old contact/support links we have on file don't work, either.
Can anyone tell me what the new process is to request network licenses?
Thank you.
4 REPLIES 4
TravisNave
You can use the online method to activate your license here:
http://knowledge.autodesk.com/installation-and-licensing
-or-
https://registeronce.autodesk.com/prodreg/beginRegistration.action
Or you can can call Autodesk Product Registration and Authorization:
http://en.autodesk.ca/adsk/servlet/index?siteID=9719649&id=9830778
1-800-551-1490 > Option 1 (English) > Option 2 > (Network)
Asia / Pacific: 65.6735.5688
Europe / Middle East / Asia: 41.32.723.9595
You will need to provide your serial number and ethernet ID of the license server.
www.licenseparser.com > This will break down your current license file into plain english and you will find the serial number there.
You should download the lastest server tools here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Latest-...
Good Luck!
Autodesk Forums:
in reply to: TravisNave
Thank you very much for your thorough and very speedy response. I worked my way through all the links--I hit some of them before posting, but I wanted to be thorough. None of them yielded a license file, but I'm confident that I can get on the right track once I set up some time for a lengthy phone session. I had no idea what contact number was, so thank you for providing that, also.
TravisNave
No problem.  I am trying to correct all the links myself and get the right ones listed.  Shouldn't take you too much time to get a license.  You can also try to do it by logging in with your Subscription account:  https://registeronce.autodesk.com/prodreg/beginRegistration.action
Good Luck!
Autodesk Forums:
None of our existing licenses appear any more when I use that 'registeronce' link with our existing logins. We are in the process of trying to contact an Autodesk representative to restore the licenses associated with our logins.
Administrator Productivity
