I have an addin that works with inventor. I would like to include this with my deployment so that it gets installed when the deployment is ran.
To get this to work, I have to manually add a file to the C:\ProgramData\Autodesk\Inventor 2014\Addins folder and also add one file to the C:\Program Files\Autodesk\Inventor 2014\Bin folder.
How would be the best way to get this to be included with the deployment?
Solved by david.lau. Go to Solution.
....and include the batch in the deployment under the "Additional software" node? That is what I was thinking, but wanted to make sure there was not another way.
