Installation & Licensing
How do I deactivate my license on a laptop that is dead?
4 REPLIES 4
simon
446 Views, 4 Replies
Hi - I am using AutoCAD LT 2013 for Mac, this was installed on my MacBook Pro which developed a fault. It was sent to Apple for repair, but was not actually repairable, so they sent me a replacement.
So now I think I need to deactivate the license on a laptop that no longer exists before I can use it again on my new MacBook? Any ideas?
4 REPLIES 4
TravisNave
in reply to: simon
You simply just need to reactivate the license on the replacement laptop.  If you need an activation code, you can get one manually by contacting Autodesk.
You can use the online method to activate your license here:
http://usa.autodesk.com/adsk/servlet/pc/item?id=18424632&siteID=123112
Or you can can call Autodesk Product Registration and Authorization:
http://en.autodesk.ca/adsk/servlet/index?siteID=9719649&id=9830778
1-800-551-1490 > Option 1 (English) > Option 1 > (Stand-alone)
Asia / Pacific: 65.6735.5688
Europe / Middle East / Asia: 41.32.723.9595
You will need to provide your serial number and the request code.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
simon
in reply to: TravisNave
Thanks for the reply Travis, however this does not work - I get a message telling me I have reached the maximum installs for my product. How can I deativate on the machine I no longer have?
TravisNave
in reply to: simon
You don't. Simply call that number listed and get a new activation code and you will be good to go. 🙂
Autodesk Forums:
simon
Sorted!
Thank you.
Administrator Productivity
