I have AutoCAD LT 2014 that I downloaded and bought the license for. I don't have an original disc to reinstall.
I need to transfer this to a new workstation, so I need to install AutoCAD LT on the new computer. The only download I see available on AutoDesk is AutoCAD LT 2015.
Will I be able to transfer the license from 2014 to 2015??
How do I get 2014 on the new workstation?
Thanks!
Solved by DarrenP. Go to Solution.
you can download autocad lt 2014 from here
You can access most current + previous supported version Browser Download links (including the Design & Creation Suites) through Matt, Autodesks Virtual Assistant. http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
>download links>Autocad Products>Autocad LT
Please accept as a solution if this fully resolves the issue
DarrenP
