Installation & Licensing
Help me!! The license server is restarted
2 REPLIES 2
murillo.cairo
236 Views, 2 Replies
Since my computer to configure the license server is started to restart several times a day.
This has already happened with other pc and that's why I made the switch, the other pc is fixed but now my pc is at fault
Both PCs are identical in both hardware and software
Windows XP PRO SP3
2 REPLIES 2
TravisNave
in reply to: murillo.cairo
Although you may want to determine why your computer is restarting constantly, you should make sure that your LMTOOLS is configured to run as a service that starts with Windows. Make sure both checkboxes are checked on the Config Services tab. That way when your computer reboots at least your NLM will restart too.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
- Start server at Power UP
- Use Services
The two checkboxes are checked
Administrator Productivity
