Installation & Licensing
Help me!! The license server is restarted
2 REPLIES 2
241 Views, 2 Replies
Since my computer to configure the license server is started to restart several times a day.
This has already happened with other pc and that's why I made the switch, the other pc is fixed but now my pc is at fault
Both PCs are identical in both hardware and software
Windows XP PRO SP3
2 REPLIES 2
TravisNave
Although you may want to determine why your computer is restarting constantly, you should make sure that your LMTOOLS is configured to run as a service that starts with Windows. Make sure both checkboxes are checked on the Config Services tab. That way when your computer reboots at least your NLM will restart too.
Autodesk Forums:
- Start server at Power UP
- Use Services
The two checkboxes are checked
Administrator Productivity
