Installation & Licensing
Help Me Inventor 2013 Error 1920
2 REPLIES 2
1605 Views, 2 Replies
http://i779.photobucket.com/albums/yy71/beolovely/anh_zps0e3c5a28.jpg
This picture it error 1920 i try but not install program.
How do fix it. help me please
2 REPLIES 2
Curtis_Waguespack
TravisNave
First and foremost, you absolutely have to install with local Administrator privileges.  Make sure UAC is disabled and your anti-virus is temporarily disabled.  You might even consider disabling your firewall.
Next, if you still have issues, you will want to make sure that the Network Service account has full access to the C:\Program Files\Common Files\ folder and its subfolders.  If that still doesn't work, try going into Services and change the service that is failing to start up with the local system account rather than the Network Service.
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
