Hey, I'm a student at the Technical University of Eindhoven and I've had troubles with Autocad installation (Error 2738). About two weeks ago I finally was able to install it through the Educational Master Suite of which my university gave me a licensing code (they also have a network license). However, when I start it, it does not recognise the license. This is what happens when I start up Autocad. After a while it starts checking the license and I get this: When I click this small white screen away (through the startbar as I have Windows 7), it shows me this: No worries, I had two ways of activating the license right? Well, yeah, but when I try to activate it. This is all it shows me:
For what I can tell everything else in Autocad works fine, it's just that I can't do anything on the license screen. Can anybody help me with what could cause this? Thanks in advance, A worried student.
something blocking the flash to connect with the link in order to activate.. try to unable the firewalls or antivurs internet protection and that staff..
also i found this
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15102758&linkID=9240617
thanks.
For more information on this known Autodesk Support Knowledge Base article, please follow this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6404339&linkID=9240617
Additional discussion about this issue can be found here:
http://forums.autodesk.com/t5/Installation-Licensing/Blank-Activation-Screen/td-p/2862508
hmm Thanks for sharing.. 🙂 good for knowledge
