I've come a long way from buying a macbook pro only to realise the graphic card wasn't compatible with the revit programme so now I have bought the new multi flip sony vaio and much to my surprise am still having lots of issues in trying to install revit. The following is the error log I keep recieving when it comes to the last 5 files downlaoding at the end.
2014/2/16:19:19:16 iVAIO VAIO === Setup started on VAIO by iVAIO === 2014/2/16:19:19:16 iVAIO VAIO Path_Length: 149 2014/2/16:19:19:16 iVAIO VAIO Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US 2014/2/16:19:19:16 iVAIO VAIO Launch 2014/2/16:19:19:16 iVAIO VAIO CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-..." /SN 900-27962012 /PK 829F1 /student /akamai /auth authparam /sid SESSION_ID 2014/2/16:19:19:16 iVAIO VAIO Setup Windows update reboot is pending 2014/2/16:19:19:21 iVAIO VAIO Setup Autodesk Revit 2014 Will restart automatically. 2014/2/16:19:19:21 iVAIO VAIO === Setup ended ===
2014/2/16:19:23:09 iVAIO VAIO === Setup started on VAIO by iVAIO === 2014/2/16:19:23:09 iVAIO VAIO Path_Length: 149 2014/2/16:19:23:09 iVAIO VAIO Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US 2014/2/16:19:23:09 iVAIO VAIO Launch 2014/2/16:19:23:09 iVAIO VAIO CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-..." /SN 900-27962012 /PK 829F1 /student /akamai /auth authparam /sid SESSION_ID 2014/2/16:19:23:09 iVAIO VAIO Path_Length: 149 2014/2/16:19:23:09 iVAIO VAIO Current Directory C:\Users\Aqsa\AppData\Local\Temp\_AIF121.tmp 2014/2/16:19:24:00 iVAIO VAIO === Setup ended ===
2014/2/16:19:23:09 iVAIO VAIO === Setup started on VAIO by iVAIO === 2014/2/16:19:23:09 iVAIO VAIO Path_Length: 149 2014/2/16:19:23:09 iVAIO VAIO Current Directory C:\Users\Aqsa\AppData\Local\Temp\_AIF121.tmp 2014/2/16:19:23:09 iVAIO VAIO Launch 2014/2/16:19:23:38 iVAIO VAIO Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6... 2014/2/16:19:23:59 iVAIO VAIO Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6... 2014/2/16:19:23:59 iVAIO VAIO Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Aqsa\AppData\Local\Temp\_AIF121.tmp\Setup\RevitSetup.dll 2014/2/16:19:23:59 iVAIO VAIO Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/2/16:19:24:00 iVAIO VAIO PageOpen LaunchDialog 2014/2/16:19:27:03 iVAIO VAIO PageOpen LicenseDialog 2014/2/16:19:27:24 iVAIO VAIO PageOpen ProductInfoDialog 2014/2/16:19:27:24 iVAIO VAIO PageOpen ProductSelectionDialog2 2014/2/16:19:27:26 iVAIO VAIO PageOpen FullProgressDialog 2014/2/16:19:27:27 iVAIO VAIO Download Play VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST... 2014/2/16:19:27:29 iVAIO VAIO Download Complete VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST... 2014/2/16:19:27:29 iVAIO VAIO Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q 2014/2/16:19:27:36 iVAIO VAIO Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded 2014/2/16:19:27:36 iVAIO VAIO Download Play VCREDIST2008SP1X64_6161 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST... 2014/2/16:19:27:39 iVAIO VAIO Download Complete VCREDIST2008SP1X64_6161 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST... 2014/2/16:19:27:39 iVAIO VAIO Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe" /q 2014/2/16:19:27:46 iVAIO VAIO Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 Succeeded 2014/2/16:19:27:46 iVAIO VAIO Download Play VCREDIST2005X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST... 2014/2/16:19:27:47 iVAIO VAIO Download Complete VCREDIST2005X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST... 2014/2/16:19:27:47 iVAIO VAIO Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Aqsa\AppData\Local\Temp\vcredist_x86_2005.log"" " 2014/2/16:19:27:54 iVAIO VAIO Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded 2014/2/16:19:27:54 iVAIO VAIO Download Play VCREDIST2005X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST... 2014/2/16:19:27:56 iVAIO VAIO Download Complete VCREDIST2005X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST... 2014/2/16:19:27:56 iVAIO VAIO Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Aqsa\AppData\Local\Temp\vcredist_x64_2005.log"" " 2014/2/16:19:28:03 iVAIO VAIO Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded 2014/2/16:19:28:04 iVAIO VAIO Download Play VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST... 2014/2/16:19:28:06 iVAIO VAIO Download Complete VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST... 2014/2/16:19:28:06 iVAIO VAIO Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q 2014/2/16:19:28:09 iVAIO VAIO Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded 2014/2/16:19:28:10 iVAIO VAIO Download Play KB958314ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314... 2014/2/16:19:28:10 iVAIO VAIO Download Complete KB958314ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314... 2014/2/16:19:28:10 iVAIO VAIO Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/16:19:28:11 iVAIO VAIO Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded 2014/2/16:19:28:11 iVAIO VAIO Download Play KB958314MFCX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314... 2014/2/16:19:28:14 iVAIO VAIO Download Complete KB958314MFCX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314... 2014/2/16:19:28:14 iVAIO VAIO Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/16:19:28:18 iVAIO VAIO Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded 2014/2/16:19:28:18 iVAIO VAIO Download Play KB958314CRTX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314... 2014/2/16:19:28:18 iVAIO VAIO Download Complete KB958314CRTX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314... 2014/2/16:19:28:18 iVAIO VAIO Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/16:19:28:21 iVAIO VAIO Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded 2014/2/16:19:28:21 iVAIO VAIO Download Play KB958314OPENMPX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314... 2014/2/16:19:28:22 iVAIO VAIO Download Complete KB958314OPENMPX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314... 2014/2/16:19:28:22 iVAIO VAIO Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/16:19:28:24 iVAIO VAIO Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded 2014/2/16:19:28:24 iVAIO VAIO Download Play KB958314ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314... 2014/2/16:19:28:24 iVAIO VAIO Download Complete KB958314ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314... 2014/2/16:19:28:24 iVAIO VAIO Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/16:19:28:26 iVAIO VAIO Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded 2014/2/16:19:28:26 iVAIO VAIO Download Play KB958314MFCX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314... 2014/2/16:19:28:32 iVAIO VAIO Download Complete KB958314MFCX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314... 2014/2/16:19:28:32 iVAIO VAIO Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/16:19:28:35 iVAIO VAIO Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded 2014/2/16:19:28:35 iVAIO VAIO Download Play KB958314CRTX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314... 2014/2/16:19:28:36 iVAIO VAIO Download Complete KB958314CRTX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314... 2014/2/16:19:28:36 iVAIO VAIO Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/16:19:28:38 iVAIO VAIO Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded 2014/2/16:19:28:39 iVAIO VAIO Download Play KB958314OPENMPX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314... 2014/2/16:19:28:39 iVAIO VAIO Download Complete KB958314OPENMPX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314... 2014/2/16:19:28:39 iVAIO VAIO Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/16:19:28:41 iVAIO VAIO Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded 2014/2/16:19:28:42 iVAIO VAIO Download Play VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST... 2014/2/16:19:28:43 iVAIO VAIO Download Complete VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST... 2014/2/16:19:28:43 iVAIO VAIO Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Aqsa\AppData\Local\Temp\vcredist_x86_2005.log"" " 2014/2/16:19:28:50 iVAIO VAIO Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded 2014/2/16:19:28:51 iVAIO VAIO Download Play VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST... 2014/2/16:19:28:52 iVAIO VAIO Download Complete VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST... 2014/2/16:19:28:52 iVAIO VAIO Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Aqsa\AppData\Local\Temp\vcredist_x64_2005.log"" " 2014/2/16:19:28:59 iVAIO VAIO Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Succeeded 2014/2/16:19:29:00 iVAIO VAIO Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/DIRECTX.... 2014/2/16:19:29:03 iVAIO VAIO Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/DIRECTX.... 2014/2/16:19:29:03 iVAIO VAIO Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent 2014/2/16:19:29:15 iVAIO VAIO Install DirectX® Runtime Succeeded 2014/2/16:19:29:15 iVAIO VAIO Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/16:19:29:19 iVAIO VAIO Install FaroSDK Succeeded 2014/2/16:19:29:20 iVAIO VAIO Download Play RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_... 2014/2/16:19:36:52 iVAIO VAIO Download Complete RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_... 2014/2/16:19:36:53 iVAIO VAIO Installing Autodesk® Revit® 2014: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2014\x64\en-us\RVT2014\RVT2014.mst;C:\Users\Aqsa\AppData\Local\Temp\_AIF121.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/16:19:49:57 iVAIO VAIO Install Autodesk® Revit® 2014 Succeeded 2014/2/16:19:49:58 iVAIO VAIO Download Play RVT2014_en-us http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_... 2014/2/16:19:50:08 iVAIO VAIO Download Aborted RVT2014_en-us http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_... 2014/2/16:19:50:08 iVAIO VAIO Install Autodesk® Revit® 2014 Language Pack Failed Download Failed, Installation aborted, Result=1603 2014/2/16:19:56:01 iVAIO VAIO Rollback Autodesk® Revit® 2014 Succeeded 2014/2/16:19:56:08 iVAIO VAIO Rollback FaroSDK Succeeded 2014/2/16:19:56:08 iVAIO VAIO Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2014/2/16:19:56:08 iVAIO VAIO Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1619 2014/2/16:19:56:08 iVAIO VAIO Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1619 2014/2/16:19:56:22 iVAIO VAIO Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded 2014/2/16:19:56:36 iVAIO VAIO Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded 2014/2/16:19:56:50 iVAIO VAIO Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded 2014/2/16:19:56:57 iVAIO VAIO Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded 2014/2/16:19:57:09 iVAIO VAIO Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded 2014/2/16:19:57:21 iVAIO VAIO Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded 2014/2/16:19:57:33 iVAIO VAIO Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded 2014/2/16:19:57:40 iVAIO VAIO Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded 2014/2/16:19:57:40 iVAIO VAIO Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619 2014/2/16:19:57:40 iVAIO VAIO Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619 2014/2/16:19:57:40 iVAIO VAIO PageOpen InstallCompleteDialog 2014/2/16:20:05:23 iVAIO VAIO === Setup ended ===
2014/2/16:20:15:48 iVAIO VAIO === Setup started on VAIO by iVAIO === 2014/2/16:20:15:48 iVAIO VAIO Path_Length: 149 2014/2/16:20:15:48 iVAIO VAIO Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US 2014/2/16:20:15:48 iVAIO VAIO Launch 2014/2/16:20:15:48 iVAIO VAIO CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-..." /SN 900-27962012 /PK 829F1 /student /akamai /auth authparam /sid SESSION_ID 2014/2/16:20:15:48 iVAIO VAIO Setup Windows update reboot is pending 2014/2/16:20:15:56 iVAIO VAIO Setup Autodesk Revit 2014 Will restart automatically. 2014/2/16:20:15:56 iVAIO VAIO === Setup ended ===
2014/2/16:20:42:09 iVAIO VAIO === Setup started on VAIO by iVAIO === 2014/2/16:20:42:09 iVAIO VAIO Path_Length: 149 2014/2/16:20:42:09 iVAIO VAIO Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US 2014/2/16:20:42:09 iVAIO VAIO Launch 2014/2/16:20:42:09 iVAIO VAIO CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-..." /SN 900-27962012 /PK 829F1 /student /akamai /auth authparam /sid SESSION_ID 2014/2/16:20:42:09 iVAIO VAIO Path_Length: 149 2014/2/16:20:42:09 iVAIO VAIO Current Directory C:\Users\Aqsa\AppData\Local\Temp\_AI77FE.tmp 2014/2/16:20:42:11 iVAIO VAIO === Setup ended ===
2014/2/16:20:42:09 iVAIO VAIO === Setup started on VAIO by iVAIO === 2014/2/16:20:42:09 iVAIO VAIO Path_Length: 149 2014/2/16:20:42:09 iVAIO VAIO Current Directory C:\Users\Aqsa\AppData\Local\Temp\_AI77FE.tmp 2014/2/16:20:42:09 iVAIO VAIO Launch 2014/2/16:20:42:10 iVAIO VAIO Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6... 2014/2/16:20:42:10 iVAIO VAIO Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Aqsa\AppData\Local\Temp\_AI77FE.tmp\Setup\RevitSetup.dll 2014/2/16:20:42:10 iVAIO VAIO Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/2/16:20:42:10 iVAIO VAIO PageOpen LaunchDialog 2014/2/16:20:47:36 iVAIO VAIO PageOpen LicenseDialog 2014/2/16:20:48:05 iVAIO VAIO PageOpen ProductInfoDialog 2014/2/16:20:48:05 iVAIO VAIO PageOpen ProductSelectionDialog2 2014/2/16:20:48:08 iVAIO VAIO PageOpen FullProgressDialog 2014/2/16:20:48:08 iVAIO VAIO Download Skipped VCREDIST2005X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST... 2014/2/16:20:48:08 iVAIO VAIO Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Aqsa\AppData\Local\Temp\vcredist_x86_2005.log"" " 2014/2/16:20:48:17 iVAIO VAIO Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded 2014/2/16:20:48:18 iVAIO VAIO Download Skipped KB958314ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314... 2014/2/16:20:48:18 iVAIO VAIO Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/16:20:48:19 iVAIO VAIO Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded 2014/2/16:20:48:19 iVAIO VAIO Download Skipped KB958314MFCX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314... 2014/2/16:20:48:19 iVAIO VAIO Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/16:20:48:23 iVAIO VAIO Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded 2014/2/16:20:48:23 iVAIO VAIO Download Skipped KB958314CRTX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314... 2014/2/16:20:48:23 iVAIO VAIO Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/16:20:48:25 iVAIO VAIO Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded Reboot is required 2014/2/16:20:48:25 iVAIO VAIO Download Skipped KB958314OPENMPX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314... 2014/2/16:20:48:25 iVAIO VAIO Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/16:20:48:27 iVAIO VAIO Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded Reboot is required 2014/2/16:20:48:27 iVAIO VAIO Download Skipped KB958314ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314... 2014/2/16:20:48:27 iVAIO VAIO Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/16:20:48:28 iVAIO VAIO Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded Reboot is required 2014/2/16:20:48:28 iVAIO VAIO Download Skipped KB958314MFCX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314... 2014/2/16:20:48:28 iVAIO VAIO Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/16:20:48:30 iVAIO VAIO Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded Reboot is required 2014/2/16:20:48:30 iVAIO VAIO Download Skipped KB958314CRTX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314... 2014/2/16:20:48:30 iVAIO VAIO Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/16:20:48:32 iVAIO VAIO Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded Reboot is required 2014/2/16:20:48:32 iVAIO VAIO Download Skipped KB958314OPENMPX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314... 2014/2/16:20:48:32 iVAIO VAIO Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/16:20:48:34 iVAIO VAIO Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded Reboot is required 2014/2/16:20:48:34 iVAIO VAIO Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/DIRECTX.... 2014/2/16:20:48:34 iVAIO VAIO Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent 2014/2/16:20:48:38 iVAIO VAIO Install DirectX® Runtime Succeeded 2014/2/16:20:48:38 iVAIO VAIO Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/16:20:48:42 iVAIO VAIO Install FaroSDK Succeeded Reboot is required 2014/2/16:20:48:42 iVAIO VAIO Download Skipped RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_... 2014/2/16:20:48:43 iVAIO VAIO Installing Autodesk® Revit® 2014: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2014\x64\en-us\RVT2014\RVT2014.mst;C:\Users\Aqsa\AppData\Local\Temp\_AI77FE.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/16:21:00:07 iVAIO VAIO Install Autodesk® Revit® 2014 Succeeded 2014/2/16:21:00:08 iVAIO VAIO Download Play RVT2014_en-us http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_... 2014/2/16:21:00:21 iVAIO VAIO Download Aborted RVT2014_en-us http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_... 2014/2/16:21:00:21 iVAIO VAIO Install Autodesk® Revit® 2014 Language Pack Failed Download Failed, Installation aborted, Result=1603 2014/2/16:21:05:42 iVAIO VAIO Rollback Autodesk® Revit® 2014 Succeeded 2014/2/16:21:05:44 iVAIO VAIO Rollback FaroSDK Succeeded 2014/2/16:21:05:44 iVAIO VAIO Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2014/2/16:21:05:46 iVAIO VAIO Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded 2014/2/16:21:05:47 iVAIO VAIO Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded 2014/2/16:21:05:49 iVAIO VAIO Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded 2014/2/16:21:05:50 iVAIO VAIO Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded 2014/2/16:21:05:51 iVAIO VAIO Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded 2014/2/16:21:05:53 iVAIO VAIO Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded 2014/2/16:21:05:55 iVAIO VAIO Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded 2014/2/16:21:05:56 iVAIO VAIO Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded 2014/2/16:21:05:56 iVAIO VAIO Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619 2014/2/16:21:05:56 iVAIO VAIO PageOpen InstallCompleteDialog 2014/2/16:21:54:10 iVAIO VAIO === Setup ended ===
2014/2/20:09:53:56 iVAIO VAIO === Setup started on VAIO by iVAIO === 2014/2/20:09:53:56 iVAIO VAIO Path_Length: 149 2014/2/20:09:53:56 iVAIO VAIO Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US 2014/2/20:09:53:56 iVAIO VAIO Launch 2014/2/20:09:53:56 iVAIO VAIO CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-..." /SN 900-27962012 /PK 829F1 /student /akamai /auth authparam /sid SESSION_ID 2014/2/20:09:53:56 iVAIO VAIO Path_Length: 149 2014/2/20:09:53:56 iVAIO VAIO Current Directory C:\Users\Aqsa\AppData\Local\Temp\_AI8BFF.tmp 2014/2/20:09:53:58 iVAIO VAIO === Setup ended ===
2014/2/20:09:53:57 iVAIO VAIO === Setup started on VAIO by iVAIO === 2014/2/20:09:53:57 iVAIO VAIO Path_Length: 149 2014/2/20:09:53:57 iVAIO VAIO Current Directory C:\Users\Aqsa\AppData\Local\Temp\_AI8BFF.tmp 2014/2/20:09:53:57 iVAIO VAIO Launch 2014/2/20:09:53:58 iVAIO VAIO Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6... 2014/2/20:09:53:58 iVAIO VAIO Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Aqsa\AppData\Local\Temp\_AI8BFF.tmp\Setup\RevitSetup.dll 2014/2/20:09:53:58 iVAIO VAIO Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/2/20:09:53:58 iVAIO VAIO PageOpen LaunchDialog 2014/2/20:09:56:25 iVAIO VAIO PageOpen LicenseDialog 2014/2/20:09:56:30 iVAIO VAIO === Setup ended ===
2014/2/20:09:59:44 iVAIO VAIO === Setup started on VAIO by iVAIO === 2014/2/20:09:59:44 iVAIO VAIO Path_Length: 149 2014/2/20:09:59:44 iVAIO VAIO Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US 2014/2/20:09:59:44 iVAIO VAIO Launch 2014/2/20:09:59:44 iVAIO VAIO CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-..." /SN 900-27962012 /PK 829F1 /student /akamai /auth authparam /sid SESSION_ID 2014/2/20:09:59:44 iVAIO VAIO Path_Length: 149 2014/2/20:09:59:44 iVAIO VAIO Current Directory C:\Users\Aqsa\AppData\Local\Temp\_AIDBEB.tmp 2014/2/20:09:59:46 iVAIO VAIO === Setup ended ===
2014/2/20:09:59:45 iVAIO VAIO === Setup started on VAIO by iVAIO === 2014/2/20:09:59:45 iVAIO VAIO Path_Length: 149 2014/2/20:09:59:45 iVAIO VAIO Current Directory C:\Users\Aqsa\AppData\Local\Temp\_AIDBEB.tmp 2014/2/20:09:59:45 iVAIO VAIO Launch 2014/2/20:09:59:45 iVAIO VAIO Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6... 2014/2/20:09:59:45 iVAIO VAIO Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Aqsa\AppData\Local\Temp\_AIDBEB.tmp\Setup\RevitSetup.dll 2014/2/20:09:59:45 iVAIO VAIO Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/2/20:09:59:46 iVAIO VAIO PageOpen LaunchDialog 2014/2/20:10:02:14 iVAIO VAIO PageOpen LicenseDialog 2014/2/20:10:02:23 iVAIO VAIO PageOpen ProductInfoDialog 2014/2/20:10:02:23 iVAIO VAIO PageOpen ProductSelectionDialog2 2014/2/20:10:02:27 iVAIO VAIO PageOpen FullProgressDialog 2014/2/20:10:02:28 iVAIO VAIO Download Skipped VCREDIST2005X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST... 2014/2/20:10:02:28 iVAIO VAIO Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Aqsa\AppData\Local\Temp\vcredist_x86_2005.log"" " 2014/2/20:10:02:36 iVAIO VAIO Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded 2014/2/20:10:02:36 iVAIO VAIO Download Skipped KB958314ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314... 2014/2/20:10:02:36 iVAIO VAIO Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/20:10:02:38 iVAIO VAIO Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded 2014/2/20:10:02:38 iVAIO VAIO Download Skipped KB958314MFCX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314... 2014/2/20:10:02:38 iVAIO VAIO Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/20:10:02:42 iVAIO VAIO Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded 2014/2/20:10:02:42 iVAIO VAIO Download Skipped KB958314CRTX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314... 2014/2/20:10:02:42 iVAIO VAIO Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/20:10:02:45 iVAIO VAIO Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded 2014/2/20:10:02:45 iVAIO VAIO Download Skipped KB958314OPENMPX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314... 2014/2/20:10:02:45 iVAIO VAIO Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/20:10:02:47 iVAIO VAIO Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded 2014/2/20:10:02:47 iVAIO VAIO Download Skipped KB958314ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314... 2014/2/20:10:02:47 iVAIO VAIO Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/20:10:02:49 iVAIO VAIO Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded 2014/2/20:10:02:49 iVAIO VAIO Download Skipped KB958314MFCX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314... 2014/2/20:10:02:49 iVAIO VAIO Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/20:10:02:52 iVAIO VAIO Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded 2014/2/20:10:02:52 iVAIO VAIO Download Skipped KB958314CRTX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314... 2014/2/20:10:02:52 iVAIO VAIO Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/20:10:02:55 iVAIO VAIO Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded 2014/2/20:10:02:55 iVAIO VAIO Download Skipped KB958314OPENMPX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314... 2014/2/20:10:02:55 iVAIO VAIO Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/20:10:02:57 iVAIO VAIO Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded 2014/2/20:10:02:58 iVAIO VAIO Download Skipped VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST... 2014/2/20:10:02:58 iVAIO VAIO Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Aqsa\AppData\Local\Temp\vcredist_x86_2005.log"" " 2014/2/20:10:03:08 iVAIO VAIO Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded 2014/2/20:10:03:08 iVAIO VAIO Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/DIRECTX.... 2014/2/20:10:03:08 iVAIO VAIO Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent 2014/2/20:10:03:11 iVAIO VAIO Install DirectX® Runtime Succeeded 2014/2/20:10:03:11 iVAIO VAIO Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/20:10:03:14 iVAIO VAIO Install FaroSDK Succeeded 2014/2/20:10:03:14 iVAIO VAIO Download Skipped RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_... 2014/2/20:10:03:15 iVAIO VAIO Installing Autodesk® Revit® 2014: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2014\x64\en-us\RVT2014\RVT2014.mst;C:\Users\Aqsa\AppData\Local\Temp\_AIDBEB.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/20:10:19:52 iVAIO VAIO Install Autodesk® Revit® 2014 Succeeded 2014/2/20:10:19:52 iVAIO VAIO Download Play RVT2014_en-us http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_... 2014/2/20:10:19:58 iVAIO VAIO Download Aborted RVT2014_en-us http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_... 2014/2/20:10:19:58 iVAIO VAIO Install Autodesk® Revit® 2014 Language Pack Failed Download Failed, Installation aborted, Result=1603 2014/2/20:10:25:39 iVAIO VAIO Rollback Autodesk® Revit® 2014 Succeeded 2014/2/20:10:25:41 iVAIO VAIO Rollback FaroSDK Succeeded 2014/2/20:10:25:41 iVAIO VAIO Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2014/2/20:10:25:41 iVAIO VAIO Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1619 2014/2/20:10:25:44 iVAIO VAIO Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded 2014/2/20:10:25:46 iVAIO VAIO Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded 2014/2/20:10:25:48 iVAIO VAIO Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded 2014/2/20:10:25:50 iVAIO VAIO Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded 2014/2/20:10:25:52 iVAIO VAIO Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded 2014/2/20:10:25:55 iVAIO VAIO Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded 2014/2/20:10:25:57 iVAIO VAIO Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded 2014/2/20:10:25:59 iVAIO VAIO Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded 2014/2/20:10:25:59 iVAIO VAIO Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
I hope that you can provide me with more of an insight into this.
Thanks guys!!!
