Installation & Licensing
Employee
62 Kudos
Post 21 of 23
Re: Help install Revit 2013 - Library problem
04-16-2013 04:45 AM in reply to: alex.bertoncelli
Still no information in the log files as to why the install is failing. At this point the only thing I can recommend is to uninstall and reinstall all the Autodesk software.
http://usa.autodesk.com/getdoc/id=TS45252
Danny
Danny Hubbard
QA Analyst
0 Kudos
Post 22 of 23
04-17-2013 07:48 AM in reply to: DannyHubbard
I installed every Autodesk product and the installation of Revit 2013 was fine! thank you Danny.
Member
1 Kudo
Post 23 of 23
05-30-2013 10:41 PM in reply to: alex.bertoncelli
I am not sure if this helps you out but I was having problems with the 2013 BAse Image Library during installation and it has ow been resolved. Please refer http://forums.autodesk.com/t5/Installation-Licensing/Material-Library-Base-Image-Image-Library-will-...
