Installation & Licensing
Help install Revit 2013 - Library problem
22 REPLIES 22
Message 1 of 23
1837 Views, 22 Replies
Hello, i have a problem installing the Material Library Medium Resolution 2013 for Revit 2013, student version. Even though my every process and antivirus are closed i cant get rid of the error message "The library could not be installed/uninstalled". I was both installing Revit normally either running the .msi file from the "content" folder, always the same error message. Any help?
22 REPLIES 22
Message 21 of 23
DannyHubbard
Still no information in the log files as to why the install is failing. At this point the only thing I can recommend is to uninstall and reinstall all the Autodesk software.
http://usa.autodesk.com/getdoc/id=TS45252
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
Message 22 of 23
in reply to: DannyHubbard
I installed every Autodesk product and the installation of Revit 2013 was fine! thank you Danny.
Message 23 of 23
I am not sure if this helps you out but I was having problems with the 2013 BAse Image Library during installation and it has ow been resolved. Please refer http://forums.autodesk.com/t5/Installation-Licensing/Material-Library-Base-Image-Image-Library-will-...
Administrator Productivity
