Installation & Licensing
help!! i cant download revit architecture 2012!!
1 REPLY 1
a0070867
386 Views, 1 Reply
I cannot even install Revit Architecture 2012! i clicked'Install On Com' and about 10s later, it says failed!
this is the log file for Autodesk Design review 2012
2012/9/11:11:10:17    user    USER-PC    === Setup started on USER-PC by user ===
2012/9/11:11:10:17    user    USER-PC    Launch
2012/9/11:11:11:08    user    USER-PC    === Setup ended ===
2012/9/11:11:11:09    user    USER-PC    PageOpen    LaunchDialog
2012/9/11:11:24:51    user    USER-PC    PageOpen    LicenseDialog
2012/9/11:18:23:54    user    USER-PC    PageOpen    ProductInfoDialog
2012/9/11:18:27:33    user    USER-PC    PageOpen    ProductSelectionDialog2
2012/9/11:18:27:47    user    USER-PC    PageOpen    FullProgressDialog
2012/9/11:18:27:47    user    USER-PC    Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/9/11:18:27:58    user    USER-PC    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Succeeded
2012/9/11:18:27:58    user    USER-PC    Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\user\AppData\Local\Temp\vcredist_x86_2010.log
2012/9/11:18:28:00    user    USER-PC    Install    Microsoft Visual C++ 2010 Redistributable (x86)    Failed    Installation aborted, Result=1603
2012/9/11:18:28:00    user    USER-PC    Rollback    Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1619
2012/9/11:18:31:56    user    USER-PC    === Setup started on USER-PC by user ===
2012/9/11:18:31:56    user    USER-PC    Launch
2012/9/11:18:32:38    user    USER-PC    === Setup ended ===
2012/9/11:18:31:57    user    USER-PC    === Setup started on USER-PC by user ===
2012/9/11:18:31:57    user    USER-PC    Launch
2012/9/11:18:32:38    user    USER-PC    PageOpen    LaunchDialog
2012/9/11:18:33:13    user    USER-PC    PageOpen    LicenseDialog
2012/9/11:18:33:16    user    USER-PC    PageOpen    ProductSelectionDialog2
2012/9/11:18:33:24    user    USER-PC    PageOpen    LicenseDialog
2012/9/11:18:33:26    user    USER-PC    PageOpen    LaunchDialog
2012/9/11:18:34:01    user    USER-PC    PageOpen    BeginDeploymentDialog
2012/9/11:18:34:04    user    USER-PC    PageOpen    LaunchDialog
2012/9/11:18:34:35    user    USER-PC    PageOpen    LicenseDialog
2012/9/11:18:34:54    user    USER-PC    PageOpen    ProductInfoDialog
2012/9/11:18:35:15    user    USER-PC    PageOpen    ProductSelectionDialog2
2012/9/11:18:35:31    user    USER-PC    PageOpen    FullProgressDialog
2012/9/11:18:35:31    user    USER-PC    Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\user\AppData\Local\Temp\vcredist_x86_2010.log
2012/9/11:18:35:33    user    USER-PC    Install    Microsoft Visual C++ 2010 Redistributable (x86)    Failed    Installation aborted, Result=1603
1 REPLY 1
TravisNave
in reply to: a0070867
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
