I cannot install Autodesk Inventor 2015 and I keep getting the same error message everytime. I have used inventor professional 2014 with the same computer specs/on the same machine but 2015 is refusing to be installed.
This is what I get:
Error1335. The cabinet file 'Common~1.cab' required for this installation is corrupt and cannot be used. This could indicate a network error, an error reading from the CD-ROM, or a problem with this package.
I get the error when Autodesk material library 2015 low image... is being installed.
Please note I am trying to install from the Autodesk website and not using any disks etc. Please see attached picture.
When I ignore the Error1335 message I get the Error2350.FDI server error. See attached picture.
I would really appreciate any help. Thanks a lot for your time.
Solved by TravisNave. Go to Solution.
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
