Installation & Licensing
New Member
0 Kudos
Post 1 of 4
Help!!!! error 1722 when installed 3D max2012 and Autocad 2012 in win7 32bit
1798 Views, 3 Replies
09-28-2012 06:02 AM
Help!!!! error 1722 when installed 3D max2012 and Autocad 2012 in win7 32bit~
I tried several times...but failed...
here is the log....
Thank you very much!
New Member
0 Kudos
Post 2 of 4
Re: Help!!!! error 1722 when installed 3D max2012 and Autocad 2012 in win7 32bit
09-28-2012 06:07 AM in reply to: zjqsszx10
902 Kudos
Post 3 of 4
10-03-2012 11:07 AM in reply to: zjqsszx10
If you've already got another materials library installed, remove it first.  That is where your failure exists.  You can also try installing your product without the materials library, then go back and add it afterwards.
New Member
0 Kudos
Post 4 of 4
Re: Help!!!! Error 1722 when installed 3D max2012 and Autocad 2012 in win7 32bit
10-14-2012 10:40 PM in reply to: zjqsszx10
i have the exact same problem.. could really use some help. I've tried about 50 different ways to supposedly "fix" error 1722 with not change what so ever.
i don't know where i can find the log or i would up load it
the error occurs right after it attempts to set up or install the inventor server
please help!
