Installation & Licensing
Help downloading Revit Arch. 2012
1 REPLY 1
metcaljr
137 Views, 1 Reply
I tried downloading Revit Arch. 2012 and it made it all the way to the end after taking almost two hours and it failed to download twice. Anyone else have this problem???
1 REPLY 1
TravisNave
in reply to: metcaljr
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
