Hi we have design suite 2013 2 licences we cant run 3dmax, revit and autocad at the same time as we jump between both products easily.
It says licence error.
we should be able to do this shouldnt we? lic is on server etc etc installs all works but individually.
if my partner has revit and 3dmax open and i try and open max it says no licence.
help thanks!
Hi Simonn,
Thank you for using Autodesk Discussion forums.
If you have two seats Design suite 2013 network license, the following scenarios can be expected:
If the above mentioned scenarios are not observed in your setup, please let me know and I’ll open a support case and work with you on this issue.
