Installation & Licensing
Distinguished Contributor
1 Kudo
Post 1 of 9
Help! 2011 Installs Only - NOT 2012
344 Views, 8 Replies
10-25-2011 03:24 PM
It appears that I successfully downloaded the 2012 version for 64 bit.
However, the previous version of the application (2011) is the only version that will installs.
Why?
Thanks for your comments,
Clint Hill
1 Kudo
Post 2 of 9
Install Issues - 64-bit NV Freedom 2012 & NVF 2011 Uninstall
10-26-2011 04:01 AM in reply to: chillme1
Assistance is needed in installing NavisWorks Freedom 2012 on a Win 7 64-bit system.
I deleted all support folders for NavisWorks Freedom 2011 but the attached message shows up while attempting to uninstall the Language Pack saying I must first uninstall 2011 N.V. Freedom.
Must I resort to modifying the REGISTRY?
Clint Hill
33 Kudos
Post 3 of 9
Re: Help! 2011 Installs Only - NOT 2012
10-26-2011 04:01 PM in reply to: chillme1
Chill, Can you provide more information about the issue you're having? Are you sure you have a 64bit machine? What happens when you start running the installation? Do you have any error messages? Do you have the log file that you can upload?
Darin Green
Synergis Technologies
If this resolve your issue/question, give Kudos or Accept as Solution...
33 Kudos
Post 4 of 9
Re: Install Issues - 64-bit NV Freedom 2012 & NVF 2011 Uninstall
10-27-2011 07:20 AM in reply to: chillme1
Install the Windows CleanUp utility to remove NWF 2011 and the language pack.
http://www.softpedia.com/dyn-postdownload.php?p=18442&t=4&i=1
Darin Green
Product Support
52 Kudos
Post 5 of 9
10-31-2011 04:13 AM in reply to: chillme1
This is the new tool from Microsoft to clean the corrupted installations (replacing the earlier tool)
http://support.microsoft.com/mats/Program_Install_and_Uninstall
Once the old version is cleaned up you can use the same utility to troubleshoot the 2012 installation error.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
1 Kudo
Post 6 of 9
10-31-2011 06:32 AM in reply to: hashim.mundol
I am currently attempting a reinstallation per your suggestion.
Clint Hill
Product Support
31 Kudos
Post 7 of 9
11-21-2011 09:43 AM in reply to: chillme1
hi Clint,
Just wondering if the issue with Navisworks Freedom 2012 install still persits.
Avto
Avto Chachava
1 Kudo
Post 8 of 9
11-22-2011 09:26 AM in reply to: avto
Thanks for your concern. It appears that the computer policies have changed and it appears that the installation issue was due to this policy change; not allowing non-administrators to install software.
Clint Hill
Product Support
31 Kudos
Post 9 of 9
11-22-2011 09:31 AM in reply to: chillme1
Thank you for the update.
I'm glad to hear that the issue is resolved.
Avto Chachava
