I got this error when installing 3ds max 2015.
can anyone help?
--Setup.log
2014/11/17:22:50:28 useradmin K13040231 === Setup started on K13040231 by useradmin ===
2014/11/17:22:50:28 useradmin K13040231 Path_Length: 155
2014/11/17:22:50:28 useradmin K13040231 Current Directory K:
2014/11/17:22:50:28 useradmin K13040231 Launch
2014/11/17:22:50:28 useradmin K13040231 CommandLine
2014/11/17:22:50:28 useradmin K13040231 Current Directory C:\Temp\_AI1527.tmp
2014/11/17:22:51:35 useradmin K13040231 === Setup ended ===
2014/11/17:22:50:43 useradmin K13040231 === Setup started on K13040231 by useradmin ===
2014/11/17:22:50:43 useradmin K13040231 Path_Length: 155
2014/11/17:22:50:43 useradmin K13040231 Current Directory C:\Temp\_AI1527.tmp
2014/11/17:22:50:43 useradmin K13040231 Launch
2014/11/17:22:51:32 useradmin K13040231 PageOpen LaunchDialog
2014/11/17:22:51:34 useradmin K13040231 PageOpen LicenseDialog
2014/11/17:22:51:36 useradmin K13040231 PageOpen ProductInfoDialog
2014/11/17:22:53:26 useradmin K13040231 PageOpen ProductSelectionDialog2
2014/11/17:22:54:41 useradmin K13040231 PageOpen FullProgressDialog
2014/11/17:22:54:42 useradmin K13040231 Installing Microsoft Visual C++ 2012 Redistributable (x86): "K:\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/11/17:22:54:53 useradmin K13040231 Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/11/17:22:54:53 useradmin K13040231 Installing Microsoft Visual C++ 2012 Redistributable (x64): "K:\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/11/17:22:56:24 useradmin K13040231 Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/11/17:22:56:24 useradmin K13040231 Installing DirectX® Runtime: "K:\3rdParty\DirectX\DXSETUP.exe" /silent
2014/11/17:22:57:20 useradmin K13040231 Install DirectX® Runtime Succeeded
2014/11/17:22:57:21 useradmin K13040231 Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=ja-jp SETUP_PACKAGENAME="Autodesk 3ds Max Design 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0364-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="K:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Temp\_AI1527.tmp\Media.mst"
2014/11/17:22:57:24 useradmin K13040231 Install Autodesk® Material Library 2015 Failed Installation aborted, Result=1625
2014/11/17:22:57:26 useradmin K13040231 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/11/17:22:57:26 useradmin K13040231 Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2014/11/17:22:57:26 useradmin K13040231 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
