so what is better in a local lan GPO or SMS
I too am looking at this situation.
I need to install Outlook 2003 and AutoCAD 2005 to a bunch of machines, plus OS patches.
Will both methods work if the local user is not a local admin?
Which is easier GPO or SMS? What are the pro/cons?
dstein
|>If you're planning to deploy to a large number of clients using a GPO, you might want to compare the process pros and cons with things like Microsoft SMS or other products that allow for mass distribution and remote management. In situations where you're using Publishing vs Assignment, to a relatively small number of users within a common LAN, a GPO can work just fine. In other situations it may not. If you already know this, forgive my intrusion and just ignore me. :)
David
