Installation & Licensing
steve.frost
251 Views, 1 Reply
Graphic card Drivers
I have recently upraded to AutoCAD Electrical 2014 and keep getting Heidi driver error message, which I've been told is down to the graphics card driver. I am running a 64-bit windows XP machine and have a Nvidia Quadro FX3700 graphics card. Is there a new driver available for it? I have found a "64-bit windows 7 or 8" or a "32-bit windows XP" but cant find the combination I need.
Any help would be great.
Steve
1 REPLY 1
TravisNave
in reply to: steve.frost
Welcome to the community.
You can try this WHQL certified driver.
http://www.nvidia.com/object/quadro-tesla-grid-winxp-x64-320.49-whql-driver.html
Make sure you do a custom installation and check the box for clean install.
Also, Windows XP support is retiring.  If your machine is capable of running XP-64, then it is capable of running Windows 7.  You should consider upgrading or buying a new computer before the 2015 release.
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
