I finally got my Lic. file from AD, Put in in the specified folder, now what? How do I start the network server, the online tutorials are insan, they make no sense...
Mac Server with Student client machines...
Seems like it, I downloaded and reinstalled but it wont open the utility. I click the icon and no action.
those files in the screenshot are client side files not the license server files. Here is the guide for setting up the license server again http://upandready.typepad.com/up_and_ready/2012/01/quick-start-setting-up-a-license-server-on-mac.ht...
Did I lose ya? Is there a tech support line to call, I have students unable to get anything done in class.
thanks
I think there may be a mistunderstanding here. The license sever doesn't have anything to do with the product install it's a seperate install.
If your LMUtil isn't working that's ok. There are other ways to find that info to get your information for your license file. Alternate methods are shown at the link below.
I would be glad to email you my lic file. from the clients I get error -15.570.36
It worked fine, ran an update to Mac OS and now it wont work.
you still have the lic file on the server? Have you tried just starting the license server again? What happes when you navigate to user/local/flexnet server and run the start command?
sudo ./lmgrd -c /var/flexlm/adsk_server.lic
Are you in the right directory to run that command? Make sure you first do cd /usr/local/flexnetserver did you also confirm the lmgrd exists in that directory? If not you may need to re-install the server software.
To be honest I have no idea how to check if that file is in the directory. I am at the end of my rope here. its been 3 days trying to figure this out. Still no response via call back from Autodesk. I appreciate the help. I have already reinstalled the server software.
That folder should exist if you re installed the server software. Can you perhaps try installing on another mac and then manually copying over the folder?
I can. Can you give me the location of the proper server file I downloaded the ipv4 file and installed it. I am heading home for the day. Hope to chat with you soon!
The server should install to /usr/local/flexnetserver
https://discussions.apple.com/thread/5418731?tstart=0
Found the flexnetserver folder below is the text from the lmgrd.exe file & the lmutil.exe, these files are located in the flexnetserver folder. I am not really sure how to proceed. Does Autodesk offer phone support and who and where do I pay to get it?
