Jimmy,
This is great information... thanks for the tip...
"Jimmy Bergmark" wrote in message
news:5238250@discussion.autodesk.com...
Here is another tip:
http://jtbworld.blogspot.com/2005/05/tips-when-changing-license-server.html
Best Regards, Jimmy Bergmark
Owner/Developer - JTB World - Software development and Consulting
Blog: http://jtbworld.blogspot.com
JTB FlexReport (FLEXnet / FLEXlm report tool) -
http://www.jtbworld.com/jtbflexreport
SmartPurger (Purges automatically) - http://www.jtbworld.com/smartpurger.htm
or download some freeware at http://www.jtbworld.com
More on AutoCAD 2006 and 2007
http://www.jtbworld.com/autocad2006.htm
http://www.jtbworld.com/autocad2007.htm
"Joel Roderick" wrote in message
news:5236356@discussion.autodesk.com...
Great news...
Thanks for the help Travis... it's much appreciated...
wrote in message news:5235830@discussion.autodesk.com...
Yes, it is very simple. The software will simply ask you for the new
License Manager location when it can't find the one it is setup for. Input
the information in the box and you will be set.
Alternately, you can change the LICPATH.LIC file in the application root
folder and/or create a System Environment Variable pointing to your new
server.
It's not a major deal. You should have a smooth transition. Good luck!
