Hi:
I am experiencing a conflict between GeoPAK and Autodesk products when using the LM_LICENSE_FILE system variable. With this variable set, GeoPAK takes about 10 minutes to load; however the Autodesk products work fine. Without this variable, GeokPAK loads instantly; however Autodesk products can not see any license server other than the one located in that location's office. GeoPAK uses a hardware lock so I do not understand why the LM_LICENSE_FILE variable causes problems. Anyway - has anyone else using both of these products run into this problem ?
Thanks;
Nick Seman
