This is maddening. Our company has paid over $2000 for products that dont work and we cant call tech support!
AutoCad LT 2015 only works if we install it as a trial. If we install with a license it hangs after checking for a license. We have installed the patch, tried a freshly imaged computer, did the regedit fix on "LoadAppInit_DLLs" to zero. Nothing works. We need a fix now.
Solved by philip.s. Go to Solution.
We have also installed SP1. The product begins to load and still freezes after checking license.
Apologies for the inconvenience Wayne and we'll definitely help get you through this. Can you please try some of the suggestions below and let me know if any of them have an impact?
For network licenses:
1. Search all the registry keys: ADSKFLEX_LICENSE_FILE and confirm they have the same value. i.e. @servername.
2. Set up the environment variable
3. Confirm that the server / file is set up correctly
For standalone licenses:
1. Delete the adskflex_####_tsf.data file and restart (will prompt for reactivation)
2. Try to run with a new user account
Still cant believe that a company that has been around this long has no phone support. Along with that, the problem was our firewall not letting the license check occur, but I didnt know that because unlike most other software there was no indication that was the problem. I look forward to seeing improvements in customer service in the future. As of right now, its working.
Hi @waynestratton,
Firewall or antivirus software can definitely one of the main culprits when dealing with licensing issues, so we're happy that you were able to get it figured out. I apologize that the experience was not better for you but we do appreciated the feedback. Please let us know if there's anything else we can do for you in the future. Thank you!
@Anonymous wrote:
Hello Sir,
Here there is no Networrk license for LT Products.
Inventor LT Suite and its companion AutoCAD LT do, in fact, have network licenses.
As for phone support, that is typically offered through the Value-Added Reseller partners. That is why you need to support your local VAR. They will provide you the best support for your product.
Locate your VAR here:
http://www.autodesk.com/resellers/overview
Same issue as of yesterday on 2015. Not sure who to call or where to get help. Need this product to work
Hi @DavidSchroeder and welcome to the Autodesk Community,
Sorry to see that you are experiencing licensing issues. If you could please provide further details on the exact nature of the problem I would be happy to further assist. Screenshots would also be great (omitting any sensitive licensing information). Also, did you @philip.s's Accepted Solution above?
I look forward to hearing from you. Thanks!
Phillip-
I am having the license checking freeze up as well. However, this is for a standalone install of AutoCAD LT 2014 on a windows 8.1 OS. Please advise on how to resolve this. I tried following the directions in your solution but after completing step 1, confirming the flex process was not disabled, I could not locate any of the files you mentioned beyond that. You only reference locations for XP or Windows 7, nothing for 8 or 8.1. My file structure did not match the options you listed for Windows 7. I also tried disabling my firewall and opening the product but still get the error shown in the attached screenshot after many attempts and "try again" clicks. Please assist when able, thank you-
Hi @Anonymous,
Welcome to the community.
Sorry to hear that you cannot connect to the internet. Try installing the Poodle hotfix, in order to connect to the internet. Make sure to fully shut down the program before applying the correct hotfix, that can be downloaded from that page. Let us know if that rectifies your issue, as we are happy to help.
Thanks Matt. Prior to your reply I did some more google searching and found this hotfix you linked in your reply. That took care of the issue and I'm now able to get in and get to work. So that issue is resolved. The only remaining issue (which I read up on as well and read that it eventually goes away on it's own) is that I now get an activation email from Autodesk every time I open CAD LT now. If you know any immediate fixes for that, please let me know. Otherwise, I'll just bear with it until the notices stop.
I just had this issue with a client using AutoCAD 2015, so I'm posting in all the forums with the issues, in case anyone else runs across the same thing.
This happened after installing 2017 (which I believe installs Microsoft .NET 4.6) but they claimed the checking license issue had been happening for a couple of weeks. I tried deleting the files in the Flexnet folder, but it did not help. I mention .NET because I tried doing a Repair on AutoCAD from the Windows Control Panel and it gave me an error saying .NET 4.5 was not installed. Turns out 4.6 was installed.
I uninstalled .NET 4.6, downloaded and installed .NET 4.5, ran the Repair, then AutoCAD ran fine.
OK, so I can run it with a new user account but I still can't figure out how to make it run from my main account.
Hi @NH3MAN,
Welcome to the community!
To clarify, you are referring to a new windows account? This may signal profile corruption. If this is the case, select the corrupted account and copy the documents and settings to the new account you created, then restart and login to the new profile.
Or are you referring to your Autodesk account?
