Free trial download of Autocad 2011 crashes upon startup. Have tried rebooting computer, to no avail. All system requirements are met as per below. What gives?
Hardware:
iMac Model: 10,1
Processor: Intel Core 2 Duo
Memory: 8 GB
Video card: ATI Radeon HD 4670
Video card driver: 01.00.383
Solved by niles2k. Go to Solution.
System Language :English ?
try to use this solution
http://usa.autodesk.com/getdoc/id=TS15916540
also try the same command in the solution with sudo infront; to run as super user for the first time.
System language is english. I tried the proposed remedies, which made no difference at all. Any helpful suggestions, or does the trial download simply not work on a mac?
Did you have the beta version of Autocad for Mac installed before
if you have any of these log files please post it.
/tmp/*.log
/Library/Application Support/Autodesk/Adlm/ACD2011ENUAdlm.log
Also please post the out after running following commands in the terminal(apps->util)
sudo su
-->type the password
->then type the following command at the # prompt.
/Applications/Autodesk/AutoCAD\ 2011/AutoCAD.app/Contents/MacOS/AutoCAD -nologo
None of that stuff works; however, I uninstalled, then reinstalled, the software, which now works like a charm. Something must have gotten corrupted during the 1st install.
