Installation & Licensing
for reinstall autocad 2012 lt
1 REPLY 1
357 Views, 1 Reply
I need to find my Serial Number for AutoCAD LT 2012 to reinstall the program on my laptop.  The serial number is not on the product packaging. How do I find the serial number on autodesk.com so I can finish the installation. thanks
1 REPLY 1
TravisNave
Welcome to the forums!
You should be able to find your serial number by logging in your Subscription center.  Alternatively, if you purchased from a Reseller, they should be able to help you as well.
Autodesk Forums:
Administrator Productivity
