Installation & Licensing
Distinguished Contributor
8 Kudos
Post 31 of 38
Re: FLEXnet Publisher License Server Manager
02-21-2012 11:51 AM in reply to: DarrenP
All machines, including the server box are Windows 7 Professional 64-Bit.
I downloaded the lmadmin from Flex yesterday, so I believe it is current.
As for the boxed lmgrd that came with Inventor; I think it was 11.5 - at any rate I checked the version when I started on this sojourn to make sure lmadmin was compatible with the adskflex.exe I have, and it fell within the compatible parameters per this article. I did not however log all version numbers of everything I tried - I would have to reinstall that softare to verify 100%.
The version of adskflex.exe I am using came from the Autodesk Inventor 2012 64-Bit installer.
I have identified two problems:
  • Unable to connect to an up and running license server (lmadmin) on the same subnet/workgroup
  • Unable to correctly configure the stock Autodesk Network tools on the server box
654 Kudos
Post 32 of 38
02-21-2012 11:53 AM in reply to: subpartner
if your server is windows 7
did you use the IPv6 version of flex lm?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10976858&linkID=9240698
8 Kudos
Post 33 of 38
02-21-2012 11:57 AM in reply to: DarrenP
uh... I used what came with the installer; if thats not the same then I guess I did not. Thank you for that link, I will give it a go again tomorrow morning  and update the conversation with the results - end of day for me here now.
899 Kudos
Post 34 of 38
02-22-2012 02:08 PM in reply to: subpartner
If you had another 3rd party app using LMGRD that was working and you added the Autodesk flavor to the mix, that's probably why you were having issues.  Since your other LMGRD works, what you want instead is to combine the license managers into one.  Just use the other one.  Copy in your adskflex.exe vendor daemon and configure the service to use the other lmgrd.exe (upgrade it if necessary.)  All of my instructions are in my Combining License Files KB below in my signature.
Member
1 Kudo
Post 35 of 38
02-24-2012 03:16 AM in reply to: TravisNave
After resolving my IPv6 issue; lmadmin worked like a charm - no muss, no fuss - straight forward and simple - props for this article; excellent alternative to LMTOOLS/LMGRD.
Member
0 Kudos
Post 36 of 38
02-18-2014 10:39 AM in reply to: TravisNave
Hi Travis,
Sorry about the basic question in this advanced post!
What is the standard network license manager/ software that comes with Autodesk software and is supported by Autodesk?  Is FlexNet Publisher a 3rd party license management software that is not supported by Autodesk?
Please let me know.
Thanks!
33 Kudos
Post 37 of 38
02-18-2014 10:53 AM in reply to: rohit.khanolkar
The flexnet software that is included with the Autodesk media is supported by Autodesk. The Flexera is the developers of the stardard FlexLM license manager and FLEXnet Publisher, but Autodesk only support the FlexLM license manager "LMTOOLS".
Darin Green
Synergis Technologies
If this resolve your issue/question, give Kudos or Accept as Solution...
899 Kudos
Post 38 of 38
02-18-2014 12:26 PM in reply to: rohit.khanolkar
This thread is about an alternative license GUI from Flexera that still uses the same lmgrd master daemon but does not use LMTOOLS.  Instead it is web-based.  It works exactly the same as the one that comes with the Autodesk software because it is the same software.  It is just a different presentation.
Hope that helps.
