Installation & Licensing
FLEXnet Publisher License Server Manager
39 REPLIES 39
Message 1 of 40
TravisNave
10293 Views, 39 Replies
Have any of you given the latest FLEXnet Publisher NLM a try?  I recently installed it and think the web interface has a lot of future promise for the License Manager.  As you can see, I am currently running it with my Subscription license adskflex vendor.
1384iD879788E55355353
Enjoy!
Autodesk Forums:
Tags (1)
39 REPLIES 39
Message 2 of 40
in reply to: TravisNave
Travis,
How did you get this configured correctly?  I have been trying to but can't get it to add the adskflex vendor.  I have put the license file in the same directory as the adskflex.exe.  When I click on import it just goes back to the import screen and doesn't do anything else.
Tracy Davis
Message 3 of 40
TravisNave
Yeah, I can see how initial setup can be confusing.
What I did was create a folder named adskflex under the FLEXnet Publisher License Server Manager.  That is where I placed the adskflex.exe vendor daemon file.
Then under the licenses folder I created another adskflex folder and placed my .LIC file and my (optional) .opt options file.
After running the lmadmin and logging in thru the web interface, I went to the Vendor Daemon Configuration tab and pointed to those locations and used port 2080 and saved.  I ran the lmadmin file again (stop and start the service) and verified all was well.  Note that the paths are relative pathing.
That should get you up and running.  You can continue to update the adskflex files with each version and be good to go.
Autodesk Forums:
Message 4 of 40
Thanks Travis.  I actually had to go back a version of the FlexNet Publisher.  I was trying to configure 11.10, after everything I did, nothing worked.  I had 11.9 also, so I installed that one and everything configured correctly and is working now.  That makes me nervous however because it is my understanding that Flexera is going away from lmgrd and going with this new interface and adskflex 11.9 does not appear to be compatible with that right now.  Any experience with 11.10 yet?
Tracy
Message 5 of 40
TravisNave
Right now I am only running 11.10 on the lmgrd.exe and LMTOOLS version.  I haven't downloaded the FLEXnet Admin version of 11.10 yet.  Maybe I should go grab it and see if it works.
I can tell you that my LMTOOLS 11.10 version does work fine with the 11.9 adskflex daemon.  I don't see why the FLEXnet wouldn't... hmm...
At least you seem to be up and running.  The Flexera web interface version really isn't all that bad once you get used to it.  I would expect the old style license manager to go away.  Heck, I figured it would have been gone by now already.
Autodesk Forums:
Message 6 of 40
yea, I didn't have issues with running LMTools 11.10 with lmgrd 11.9 (11.10 isn't available from Flexera right now) and adskflex 11.9.
I didn't think there was going to be any problems with running the FlexNet admin tool either, but alas.
It is not too bad of an interface.  Hopefully if Autodesk does go with this interface, they do the installation much more user friendly, but if they don't, more job security for me..
Message 7 of 40
TravisNave
I do have the lmgrd.exe version 11.10.  It's still available, they just have pulled the click thru link.  Something about a potential security threat on that version via port 27000.  There's no case of it ever being exploited, but they are just being cautious.  Seems to still work just fine on my Autodesk licenses.
Autodesk Forums:
Message 8 of 40
DarrenP
is this free?
DarrenP
Message 9 of 40
TravisNave
in reply to: DarrenP
Darren,
In fact it is.  There is a more advanced version you can buy, of course, but the one I use is free.  Feel free to try it out.  Simply download the Windows version of lmadmin at the following link:
http://www.globes.com/support/fnp_utilities_download.htm
The latest version at the time of this post is 11.10.0.2.  (filename: lmadmin-i86_n3-11_10_0_2.exe)
Autodesk Forums:
Message 10 of 40
DarrenP
i can't get the vendor daemon to work this is the error i am getting: Vendor daemon executable doesn't exist.
DarrenP
Message 11 of 40
TravisNave
Right.  You need to go grab a copy of your adskflex.exe vendor file and place it in with your FLEXnet files.  See an example of that in my screenshot posted above.  Should work for you there.
Once configured, you should be all set.  It has a bit of a learning curve getting it set up.
Autodesk Forums:
Message 12 of 40
DarrenP
i don't think i am doing this right
this where i have the adskflex.exe: C:\Program Files\FLEXnet Publisher License Server Manager\adskflex
it keeps saying it can't find it
DarrenP
Message 13 of 40
TravisNave
That is the correct location.  Same one I am using.  In the box where you point to the vendor daemon, are you using the relative path of adskflex/adskflex.exe as shown in my (2nd) screen shot?
My adskflex.exe vendor location is here:
My *.lic license location is here:
C:\Program Files\FLEXnet Publisher License Server Manager\licenses\adskflex
My adskflex.log file is here:
C:\Program Files\FLEXnet Publisher License Server Manager\logs
EDIT: Darren, I am also using version 11.9 and not 11.10.  It's possible this isn't working in the latest release.  I am going to download and update now to find out.  If it doesn't work, I'll see about hooking you up with 11.9.
Autodesk Forums:
Message 14 of 40
DarrenP
i got past that part now i am running into critical errors now
DarrenP
Message 15 of 40
TravisNave
Anything particular?  I am upgrading now at the moment.  We'll see how this works here on 11.10.
Autodesk Forums:
Message 16 of 40
TravisNave
Ah, I see.  The critical (red) errors that you are seeing along with the number of warning (yellow) errors are simply logging.  They can be X'd out.  They were logged likely during intial setup.  You can change what gets logged in the administration settings.
On the Dashboard, click Concurrent and you should see your available licenses.  You should also be able to connect now with your Autodesk application.  Even my adskflex.opt is running and reserving licenses on it.
Running latest 11.10.0.2 version now.  Working fine.
Autodesk Forums:
Message 17 of 40
DarrenP
its working now
DarrenP
Message 18 of 40
TravisNave
Excellent.  Use it for awhile and let me know what you think.  If and when the system goes to this, we're gonna need all the experience we can get!!
Smiley Very Happy
Autodesk Forums:
Message 19 of 40
DarrenP
i like it better already
DarrenP
Message 20 of 40
Darin.Green
I been using it for a while now. I just had to drop the lmadmin.exe into my startup apps so I don't have to run it every time my machine reboot. Most importantly, I can access it the html from any machine on the domain without using remote desktop.
What do you think about it?
If this information was helpful, please consider using the Accept Solution
Administrator Productivity
