Installation & Licensing
Welcome to Autodeskā€™s Installation and Licensing Forums. Share your knowledge, ask questions, and explore popular Download, Installation, and Licensing topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
FLEXnet Licensing error:-97,121
1 REPLY 1
hardware
1151 Views, 1 Reply
Supported Product : Infrastructure Design Suite Ultimate 2014
Problem : License Problem
1. Fl
1. FlexNet License Finder dialog
2. I Give name my computer name
3. Press Next
But
Not Generate License Show an Error like
"Networking Error : Server ("Dell") not responding. Please connect systems Administrator for assistance.
NB : Inform you that this computer is Standalone PC Connected with internet but not Connected with network server.
4. When I Import License file then show this Licensing Error " A valid license could not be obtained by the network license manager."
"If you are still unable to access a license, contact your system administrator" Error [-15.570.0]
3. Press Next
But
Tags (1)
1 REPLY 1
TravisNave
in reply to: hardware
Have you set up your license manager?  And if so, is it set up on your computer?
It could be an IPv6 issue.
For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
For a Quick-Start Guide on configuring the Autodesk License Manager, please see my post for further information:
http://forums.autodesk.com/t5/Installation-Licensing/Quick-Start-Guide-for-Configuring-LMTOOLS/m-p/3...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
