Installation & Licensing
FLEXnet Licensing error:-97,​121
2 REPLIES 2
6895 Views, 2 Replies
we have users who are sharing a network license all getting this error and we dont know why. can somebody let me know what the error means and any possible solutions for this error?
2 REPLIES 2
DarrenP
what i found doing a search: http://forums.autodesk.com/t5/Autodesk-Inventor/FLEXnet-Licensing-error-97-121/td-p/3797005
DarrenP
TravisNave
-97  The desired vendor daemon is down.
1) Check the lmgrd log file, or 2) Try lmreread.
In my experience, the license master daemon is running but the adskflex.exe is not.  This can be due to a mismatch in your LIC file or it could be a compatibility issue with the adskflex.exe and your server OS.  In fact, I see this problem often on Server 2008 R2 when running a NLM newer than 11.7.  However, v11.7 typically seems to work fine on R2.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
