Installation & Licensing
FLEXnet Licensing error:-97,121
24 REPLIES 24
Message 1 of 25
jeromecastaneda
145314 Views, 24 Replies
Flexible License Manager status on Tue 3/13/2012 11:05
[Detecting lmgrd processes...]
License server status: 27000@Crown-Server
License file(s) on Crown-Server: C:\Program Files\Autodesk\Autodesk Network License Manager\License\CrownSys_Combined.lic:
Crown-Server: license server UP (MASTER) v11.9
We have problem connecting to the license server.
Here's from the Perform Status Enquiry
Vendor daemon status (on Crown-Server):
adskflex: The desired vendor daemon is down.
Check the lmgrd log file, or try lmreread.
Vendor:Host: Crown-Server
License path: 27000@Crown-Server;
Things that were done:
1. Firewalls are all disabled
2. created an exception rule (inbound and outbound) to port 2080
3. created ADSKFLEX_LICENSE_FILE in the system variable with value @203.92.109.98
4. reinstalled LMtools and created new Service to re Configure Service
Attached is the debug log for more reference. here were the last status
10:49:12 (adskflex) Vendor daemon can't talk to lmgrd (License server machine is down or not responding. (-96,491))
10:49:12 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
10:49:16 (lmgrd) adskflex exited with status 28 (Communications error)
10:49:16 (lmgrd) Please correct problem and restart daemons
thanks a lot,
Jerome
http://engr.jeromecastaneda.com/
“What we do for ourselves dies with us. What we do for others and the world remains and is immortal.” - Albert Pine
24 REPLIES 24
Message 2 of 25
orengabay
in reply to: jeromecastaneda
Try to disable any Antivirus software running on your FLEXlm license server machine. Sometimes it blocks the vendor daemon.
Oren Gabay
OpenLM - Streching your licenses to their limit
http://www.openlm.com
Message 3 of 25
jeromecastaneda
in reply to: orengabay
Hello Oren,
The antivirus is not running in the background.
Any other thoughts?
thanks,
Jerome
Message 4 of 25
Hi Jerome,
Have you managed to fix this as we are having the same problem.  Except in our case we installed the licence manager on a new server after retiring the old one, generated a new licence file with the details in and the just get that exact same error.  We have no antivirus installed on this particular server as it's only other role is as a DC and AutoCAD support have checked the licence file which is not the problem, unfortunately that's the limit of the support they are willing to give us.
We are using the 2009 suite of autocad products (Revit, Inventor and 3ds Max)
Regards
Jamie Kelly
Network Technician
Boston College, Lincolnshire, UK
Message 5 of 25
orengabay
Hi Jerome,
I further investigated this and found that it may be related with DNS issues on the license server machine.
Check your server hostname name by the "hostname" command and then try to ping this name on the license server, it should work. You can also try to use the FQDN in the license file.
Another option to check is described in IBM Rational support page - http://www-01.ibm.com/support/docview.wss?uid=swg21296320. Probably it's related to old versions of FLEXlm but worth checking.
Sincerely,
Oren
Oren Gabay
Message 6 of 25
jeromecastaneda
Hi Oren,
We can ping the server however still got the same problem.
Flexible License Manager status on Thu 3/15/2012 09:58
Error getting status: Cannot connect to license server system.
The license server manager (lmgrd) has not been started yet,
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Server name: 203.92.109.98
License path: @203.92.109.98;
FLEXnet Licensing error:-15,570
For further information, refer to the FLEXnet Licensing documentation,
Pls. advise more about FDQN in license file. how do you do that?
We're using Flexera version v11.9.0.0 build 87342 x64_n6
Jerome
Message 7 of 25
jeromecastaneda
Hi Jamie,
I went through your log file and found these last lines
10:25:13 (lmgrd) adskflex exited with status 27 (No features to serve)
10:25:13 (lmgrd) adskflex daemon found no features. Please correct
10:25:13 (lmgrd) license file and re-start daemons.
10:25:13 (lmgrd)
10:25:13 (lmgrd) This may be due to the fact that you are using
10:25:13 (lmgrd) a different license file from the one you expect.
10:25:13 (lmgrd) Check to make sure that:
10:25:13 (lmgrd) C:\Users\veritas\Desktop\CAD Licence File\Muffin.lic
10:25:13 (lmgrd) is the license file you want to use.
10:25:13 (lmgrd)
Have you done this?
Jerome
Tags (1)
Message 8 of 25
orengabay
Hi Jerome,
Can you post the header of the license file in order to check the definitions in the server & vendor lines?
SIncerely,
Oren
Message 9 of 25
jeromecastaneda
Hi Oren,
Appreciate your help.
We were able to resolve this issue.
In the LMTools first tab and Configuration using Services selected, we enabled LMTOOLS ignores license file path environment variables. Yes that did the trick with the tick. 🙂
Jerome
Tags (1)
Message 10 of 25
orengabay
Hi Jerome,
I am happy to hear that I was able to help.
Sincerely,
Oren
Message 11 of 25
I have same problem with accesing the license server.
Could you please explaine me what exactly did you do by: "we enabled LMTOOLS ignores license file path environment var".
What file have to be changed?
I would realy appreciate your answer.
Thank you
Roxana
Message 12 of 25
Hi again,
I found out but anyhow the  "LMTools ignores file path environment variables" is already checked (enabled) and it doesn't work 😞
Message 13 of 25
My office is dead in the water and all I get from tech support is an answering machine. I have tried what everyone else has done on here and so far nothing is working. Thank you ahead of time for the assistance!
Status
Flexible License Manager status on Tue 1/13/2015 13:59
License server status: 27000@dyer2
License file(s) on dyer2: E:\Autodesk Network License Manager\from email\DYER2.lic:
dyer2: license server UP (MASTER) v11.11
Vendor daemon status (on dyer2):
Vendor:Host: dyer2
License path: 27000@dyer2;
available at "www.flexerasoftware.com".
Message 14 of 25
turttledove
in reply to: turttledove
here is my log
13:55:18 (lmgrd) -----------------------------------------------
13:55:18 (lmgrd) Please Note:
13:55:18 (lmgrd)
13:55:18 (lmgrd) This log is intended for debug purposes only.
13:55:18 (lmgrd) In order to capture accurate license
13:55:18 (lmgrd) usage data into an organized repository,
13:55:18 (lmgrd) please enable report logging. Use Flexera Software LLC's
13:55:18 (lmgrd) software license administration solution,
13:55:18 (lmgrd) FlexNet Manager, to readily gain visibility
13:55:18 (lmgrd) into license usage data and to create
13:55:18 (lmgrd) insightful reports on critical information like
13:55:18 (lmgrd) license availability and usage. FlexNet Manager
13:55:18 (lmgrd) can be fully automated to run these reports on
13:55:18 (lmgrd) schedule and can be used to track license
13:55:18 (lmgrd) servers and usage across a heterogeneous
13:55:18 (lmgrd) network of servers including Windows NT, Linux
13:55:18 (lmgrd) and UNIX. Contact Flexera Software LLC at
13:55:18 (lmgrd) www.flexerasoftware.com for more details on how to
13:55:18 (lmgrd) obtain an evaluation copy of FlexNet Manager
13:55:18 (lmgrd) for your enterprise.
13:55:18 (lmgrd)
13:55:18 (lmgrd)
13:55:18 (lmgrd)
13:55:18 (lmgrd) pid 5560
13:55:18 (lmgrd) Detecting other license server manager (lmgrd) processes...
13:55:18 (lmgrd) Done rereading
13:55:18 (lmgrd) FlexNet Licensing (v11.11.0.0 build 106800 x64_n6) started on dyer2 (IBM PC) (1/13/2015)
13:55:18 (lmgrd) Copyright (c) 1988-2012 Flexera Software LLC. All Rights Reserved.
13:55:18 (lmgrd) World Wide Web: http://www.flexerasoftware.com
13:55:18 (lmgrd) License file(s): E:\Autodesk Network License Manager\from email\DYER2.lic
13:55:18 (lmgrd) lmgrd tcp-port 27000
13:55:18 (lmgrd) Starting vendor daemons ...
13:55:18 (lmgrd) Starting vendor daemon at port 2080
13:55:18 (lmgrd) Using vendor daemon port 2080 specified in license file
13:55:18 (lmgrd) Started adskflex (pid 1052)
13:55:18 (adskflex) Unable to initialize access to trusted storage: 1
13:55:18 (adskflex) FlexNet Licensing version v11.11.0.0 build 106800 x64_n6
13:55:19 (adskflex) Server started on dyer2 for:
13:55:19 (adskflex) 64300ACD_F (consisting of: 85536ACD_2011_0F
13:55:19 (adskflex) 86063ACD_2014_0F 85871ACD_2013_0F 85730ACD_2012_0F)
13:55:19 (adskflex) 85812IDSP_F (consisting of: 86123IDSP_2014_0F
13:55:19 (adskflex) 85992IDSP_2013_0F 85799IDSP_2012_0F 85882INFMDR_2012_0F
13:55:19 (adskflex) 85841ARDES_2012_0F 85850MAP3DE_2012_0F 85536ACD_2011_0F
13:55:19 (adskflex) 85601NAVSIM_2011_0F 85557MAP_2011_0F 85559TOPOBSCLNT_2011_0F
13:55:19 (adskflex) 85503MAXDES_2011_0F 85604CIV3D_2011_0F 85583LDXSP_2011_0F
13:55:19 (adskflex) 85683ARDES_2011_0F) 86123IDSP_2014_0F
13:55:19 (adskflex) Wrong hostid on SERVER line for license file:
13:55:19 (adskflex) E:\Autodesk Network License Manager\from email\DYER2.lic
13:55:19 (adskflex) SERVER line says 6cae8b25d09c, hostid is "6cae8b25d09b 6cae8b25d09a 6eae8b25d099"
13:55:19 (adskflex) Invalid hostid on SERVER line
13:55:19 (adskflex) Disabling 4 licenses from feature 64300ACD_F(034C F78B 7712 ABCE )
13:55:19 (adskflex) Disabling 5 licenses from feature 85503MAXDES_2011_0F(12CD 7F68 7C72 BD17 )
13:55:19 (adskflex) Disabling 4 licenses from feature 85536ACD_2011_0F(034C F78B 7712 ABCE )
13:55:19 (adskflex) Disabling 5 licenses from feature 85536ACD_2011_0F(12CD 7F68 7C72 BD17 )
13:55:19 (adskflex) Disabling 5 licenses from feature 85557MAP_2011_0F(12CD 7F68 7C72 BD17 )
13:55:19 (adskflex) Disabling 5 licenses from feature 85559TOPOBSCLNT_2011_0F(12CD 7F68 7C72 BD17 )
13:55:19 (adskflex) Disabling 5 licenses from feature 85583LDXSP_2011_0F(12CD 7F68 7C72 BD17 )
13:55:19 (adskflex) Disabling 5 licenses from feature 85601NAVSIM_2011_0F(12CD 7F68 7C72 BD17 )
13:55:19 (adskflex) Disabling 5 licenses from feature 85604CIV3D_2011_0F(12CD 7F68 7C72 BD17 )
13:55:19 (adskflex) Disabling 5 licenses from feature 85683ARDES_2011_0F(12CD 7F68 7C72 BD17 )
13:55:19 (adskflex) Disabling 4 licenses from feature 85730ACD_2012_0F(034C F78B 7712 ABCE )
13:55:19 (adskflex) Disabling 5 licenses from feature 85799IDSP_2012_0F(12CD 7F68 7C72 BD17 )
13:55:19 (adskflex) Disabling 5 licenses from feature 85812IDSP_F(12CD 7F68 7C72 BD17 )
13:55:19 (adskflex) Disabling 5 licenses from feature 85841ARDES_2012_0F(12CD 7F68 7C72 BD17 )
13:55:19 (adskflex) Disabling 5 licenses from feature 85850MAP3DE_2012_0F(12CD 7F68 7C72 BD17 )
13:55:19 (adskflex) Disabling 4 licenses from feature 85871ACD_2013_0F(034C F78B 7712 ABCE )
13:55:19 (adskflex) Disabling 5 licenses from feature 85882INFMDR_2012_0F(12CD 7F68 7C72 BD17 )
13:55:19 (adskflex) Disabling 5 licenses from feature 85992IDSP_2013_0F(12CD 7F68 7C72 BD17 )
13:55:19 (adskflex) Disabling 4 licenses from feature 86063ACD_2014_0F(034C F78B 7712 ABCE )
13:55:19 (adskflex) Disabling 5 licenses from feature 86123IDSP_2014_0F(12CD 7F68 7C72 BD17 )
13:55:19 (adskflex) Disabling 1 license from feature 86123IDSP_2014_0F(12DA 5CE0 D7A5 61E4 )
13:55:19 (adskflex) EXTERNAL FILTERS are OFF
13:55:19 (lmgrd) adskflex using TCP-port 2080
13:55:19 (adskflex) No valid hostids, exiting
13:55:19 (adskflex) EXITING DUE TO SIGNAL 25 Exit reason 2
13:55:19 (lmgrd) adskflex exited with status 25 (Invalid host)
13:55:19 (lmgrd) Please correct problem and restart daemons
13:55:19 (lmgrd) Rereading license file... Requested from Administrator@DYER2
13:55:19 (lmgrd) Starting vendor daemon at port 2080
13:55:19 (lmgrd) Using vendor daemon port 2080 specified in license file
13:55:19 (lmgrd) Reread: Started adskflex (pid 2164)13:55:19 (lmgrd) Done rereading
13:55:19 (lmgrd) ...Finished rereading
13:55:19 (adskflex) Unable to initialize access to trusted storage: 1
13:55:19 (adskflex) FlexNet Licensing version v11.11.0.0 build 106800 x64_n6
13:55:20 (adskflex) Server started on dyer2 for:
13:55:20 (adskflex) 64300ACD_F (consisting of: 85536ACD_2011_0F
13:55:20 (adskflex) 86063ACD_2014_0F 85871ACD_2013_0F 85730ACD_2012_0F)
13:55:20 (adskflex) 85812IDSP_F (consisting of: 86123IDSP_2014_0F
13:55:20 (adskflex) 85992IDSP_2013_0F 85799IDSP_2012_0F 85882INFMDR_2012_0F
13:55:20 (adskflex) 85841ARDES_2012_0F 85850MAP3DE_2012_0F 85536ACD_2011_0F
13:55:20 (adskflex) 85601NAVSIM_2011_0F 85557MAP_2011_0F 85559TOPOBSCLNT_2011_0F
13:55:20 (adskflex) 85503MAXDES_2011_0F 85604CIV3D_2011_0F 85583LDXSP_2011_0F
13:55:20 (adskflex) 85683ARDES_2011_0F) 86123IDSP_2014_0F
13:55:20 (adskflex) Wrong hostid on SERVER line for license file:
13:55:20 (adskflex) E:\Autodesk Network License Manager\from email\DYER2.lic
13:55:20 (adskflex) SERVER line says 6cae8b25d09c, hostid is "6cae8b25d09b 6cae8b25d09a 6eae8b25d099"
13:55:20 (adskflex) Invalid hostid on SERVER line
13:55:20 (adskflex) Disabling 4 licenses from feature 64300ACD_F(034C F78B 7712 ABCE )
13:55:20 (adskflex) Disabling 5 licenses from feature 85503MAXDES_2011_0F(12CD 7F68 7C72 BD17 )
13:55:20 (adskflex) Disabling 4 licenses from feature 85536ACD_2011_0F(034C F78B 7712 ABCE )
13:55:20 (adskflex) Disabling 5 licenses from feature 85536ACD_2011_0F(12CD 7F68 7C72 BD17 )
13:55:20 (adskflex) Disabling 5 licenses from feature 85557MAP_2011_0F(12CD 7F68 7C72 BD17 )
13:55:20 (adskflex) Disabling 5 licenses from feature 85559TOPOBSCLNT_2011_0F(12CD 7F68 7C72 BD17 )
13:55:20 (adskflex) Disabling 5 licenses from feature 85583LDXSP_2011_0F(12CD 7F68 7C72 BD17 )
13:55:20 (adskflex) Disabling 5 licenses from feature 85601NAVSIM_2011_0F(12CD 7F68 7C72 BD17 )
13:55:20 (adskflex) Disabling 5 licenses from feature 85604CIV3D_2011_0F(12CD 7F68 7C72 BD17 )
13:55:20 (adskflex) Disabling 5 licenses from feature 85683ARDES_2011_0F(12CD 7F68 7C72 BD17 )
13:55:20 (adskflex) Disabling 4 licenses from feature 85730ACD_2012_0F(034C F78B 7712 ABCE )
13:55:20 (adskflex) Disabling 5 licenses from feature 85799IDSP_2012_0F(12CD 7F68 7C72 BD17 )
13:55:20 (adskflex) Disabling 5 licenses from feature 85812IDSP_F(12CD 7F68 7C72 BD17 )
13:55:20 (adskflex) Disabling 5 licenses from feature 85841ARDES_2012_0F(12CD 7F68 7C72 BD17 )
13:55:20 (adskflex) Disabling 5 licenses from feature 85850MAP3DE_2012_0F(12CD 7F68 7C72 BD17 )
13:55:20 (adskflex) Disabling 4 licenses from feature 85871ACD_2013_0F(034C F78B 7712 ABCE )
13:55:20 (adskflex) Disabling 5 licenses from feature 85882INFMDR_2012_0F(12CD 7F68 7C72 BD17 )
13:55:20 (adskflex) Disabling 5 licenses from feature 85992IDSP_2013_0F(12CD 7F68 7C72 BD17 )
13:55:20 (adskflex) Disabling 4 licenses from feature 86063ACD_2014_0F(034C F78B 7712 ABCE )
13:55:20 (adskflex) Disabling 5 licenses from feature 86123IDSP_2014_0F(12CD 7F68 7C72 BD17 )
13:55:20 (adskflex) Disabling 1 license from feature 86123IDSP_2014_0F(12DA 5CE0 D7A5 61E4 )
13:55:20 (adskflex) EXTERNAL FILTERS are OFF
13:55:20 (lmgrd) adskflex using TCP-port 2080
13:55:20 (adskflex) No valid hostids, exiting
13:55:20 (adskflex) EXITING DUE TO SIGNAL 25 Exit reason 2
13:55:25 (lmgrd) adskflex exited with status 25 (Invalid host)
13:55:25 (lmgrd) Please correct problem and restart daemons
13:59:30 (lmgrd) Rereading license file... Requested from Administrator@DYER2
13:59:30 (lmgrd) Starting vendor daemon at port 2080
13:59:30 (lmgrd) Using vendor daemon port 2080 specified in license file
13:59:30 (lmgrd) Reread: Started adskflex (pid 4068)13:59:30 (lmgrd) Done rereading
13:59:30 (lmgrd) ...Finished rereading
13:59:30 (adskflex) Unable to initialize access to trusted storage: 1
13:59:30 (adskflex) FlexNet Licensing version v11.11.0.0 build 106800 x64_n6
13:59:32 (adskflex) Server started on dyer2 for:
13:59:32 (adskflex) 64300ACD_F (consisting of: 85536ACD_2011_0F
13:59:32 (adskflex) 86063ACD_2014_0F 85871ACD_2013_0F 85730ACD_2012_0F)
13:59:32 (adskflex) 85812IDSP_F (consisting of: 86123IDSP_2014_0F
13:59:32 (adskflex) 85992IDSP_2013_0F 85799IDSP_2012_0F 85882INFMDR_2012_0F
13:59:32 (adskflex) 85841ARDES_2012_0F 85850MAP3DE_2012_0F 85536ACD_2011_0F
13:59:32 (adskflex) 85601NAVSIM_2011_0F 85557MAP_2011_0F 85559TOPOBSCLNT_2011_0F
13:59:32 (adskflex) 85503MAXDES_2011_0F 85604CIV3D_2011_0F 85583LDXSP_2011_0F
13:59:32 (adskflex) 85683ARDES_2011_0F) 86123IDSP_2014_0F
13:59:32 (adskflex) Wrong hostid on SERVER line for license file:
13:59:32 (adskflex) E:\Autodesk Network License Manager\from email\DYER2.lic
13:59:32 (adskflex) SERVER line says 6cae8b25d09c, hostid is "6cae8b25d09b 6cae8b25d09a 6eae8b25d099"
13:59:32 (adskflex) Invalid hostid on SERVER line
13:59:32 (adskflex) Disabling 4 licenses from feature 64300ACD_F(034C F78B 7712 ABCE )
13:59:32 (adskflex) Disabling 5 licenses from feature 85503MAXDES_2011_0F(12CD 7F68 7C72 BD17 )
13:59:32 (adskflex) Disabling 4 licenses from feature 85536ACD_2011_0F(034C F78B 7712 ABCE )
13:59:32 (adskflex) Disabling 5 licenses from feature 85536ACD_2011_0F(12CD 7F68 7C72 BD17 )
13:59:32 (adskflex) Disabling 5 licenses from feature 85557MAP_2011_0F(12CD 7F68 7C72 BD17 )
13:59:32 (adskflex) Disabling 5 licenses from feature 85559TOPOBSCLNT_2011_0F(12CD 7F68 7C72 BD17 )
13:59:32 (adskflex) Disabling 5 licenses from feature 85583LDXSP_2011_0F(12CD 7F68 7C72 BD17 )
13:59:32 (adskflex) Disabling 5 licenses from feature 85601NAVSIM_2011_0F(12CD 7F68 7C72 BD17 )
13:59:32 (adskflex) Disabling 5 licenses from feature 85604CIV3D_2011_0F(12CD 7F68 7C72 BD17 )
13:59:32 (adskflex) Disabling 5 licenses from feature 85683ARDES_2011_0F(12CD 7F68 7C72 BD17 )
13:59:32 (adskflex) Disabling 4 licenses from feature 85730ACD_2012_0F(034C F78B 7712 ABCE )
13:59:32 (adskflex) Disabling 5 licenses from feature 85799IDSP_2012_0F(12CD 7F68 7C72 BD17 )
13:59:32 (adskflex) Disabling 5 licenses from feature 85812IDSP_F(12CD 7F68 7C72 BD17 )
13:59:32 (adskflex) Disabling 5 licenses from feature 85841ARDES_2012_0F(12CD 7F68 7C72 BD17 )
13:59:32 (adskflex) Disabling 5 licenses from feature 85850MAP3DE_2012_0F(12CD 7F68 7C72 BD17 )
13:59:32 (adskflex) Disabling 4 licenses from feature 85871ACD_2013_0F(034C F78B 7712 ABCE )
13:59:32 (adskflex) Disabling 5 licenses from feature 85882INFMDR_2012_0F(12CD 7F68 7C72 BD17 )
13:59:32 (adskflex) Disabling 5 licenses from feature 85992IDSP_2013_0F(12CD 7F68 7C72 BD17 )
13:59:32 (adskflex) Disabling 4 licenses from feature 86063ACD_2014_0F(034C F78B 7712 ABCE )
13:59:32 (adskflex) Disabling 5 licenses from feature 86123IDSP_2014_0F(12CD 7F68 7C72 BD17 )
13:59:32 (adskflex) Disabling 1 license from feature 86123IDSP_2014_0F(12DA 5CE0 D7A5 61E4 )
13:59:32 (adskflex) EXTERNAL FILTERS are OFF
13:59:32 (lmgrd) adskflex using TCP-port 2080
13:59:32 (adskflex) No valid hostids, exiting
13:59:32 (adskflex) EXITING DUE TO SIGNAL 25 Exit reason 2
13:59:37 (lmgrd) adskflex exited with status 25 (Invalid host)
13:59:37 (lmgrd) Please correct problem and restart daemons
Message 15 of 25
DarrenP
a possible cause: http://knowledge.autodesk.com/support/softimage/troubleshooting/caas/sfdcarticles/sfdcarticles/FLEXn...
did the MAC address change on the server
DarrenP
Message 16 of 25
DarrenP
@turttledove wrote:
here is my log
this is the problem
the MAC address did change you need to regenerate a new license file for one of these MAC addresses
DarrenP
Message 17 of 25
Wi11ink
in reply to: DarrenP
I am having exactly same problem.
How/where do I generate a new licence file?
Apologies if it's obvious, I have just taken over from the guy that originally installed this and have no idea...
Message 18 of 25
orengabay
in reply to: Wi11ink
You obviously need to generate a new license file. I would recommend you to try: https://registeronce.autodesk.com
Sincerely,
Oren
Message 19 of 25
11:09:27 (lmgrd) -----------------------------------------------
11:09:27 (lmgrd) Please Note:
11:09:27 (lmgrd)
11:09:27 (lmgrd) This log is intended for debug purposes only.
11:09:27 (lmgrd) In order to capture accurate license
11:09:27 (lmgrd) usage data into an organized repository,
11:09:27 (lmgrd) please enable report logging. Use Acresso Software Inc.'s
11:09:27 (lmgrd) software license administration solution,
11:09:27 (lmgrd) FLEXnet Manager, to readily gain visibility
11:09:27 (lmgrd) into license usage data and to create
11:09:27 (lmgrd) insightful reports on critical information like
11:09:27 (lmgrd) license availability and usage. FLEXnet Manager
11:09:27 (lmgrd) can be fully automated to run these reports on
11:09:27 (lmgrd) schedule and can be used to track license
11:09:27 (lmgrd) servers and usage across a heterogeneous
11:09:27 (lmgrd) network of servers including Windows NT, Linux
11:09:27 (lmgrd) and UNIX. Contact Acresso Software Inc. at
11:09:27 (lmgrd) www.acresso.com for more details on how to
11:09:27 (lmgrd) obtain an evaluation copy of FLEXnet Manager
11:09:27 (lmgrd) for your enterprise.
11:09:27 (lmgrd)
11:09:27 (lmgrd)
11:09:27 (lmgrd)
11:09:27 (lmgrd) pid 5892
11:09:27 (lmgrd) Detecting other license server manager (lmgrd) processes...
11:09:27 (lmgrd) RMCON already running 27000@mumdbsrv
11:09:27 (lmgrd) The license server manager (lmgrd) is already serving all vendors, exiting.
Message 20 of 25
License server status: 27003@mumdbsrv
License file(s) on mumdbsrv: D:\RAILSYS LICENCE 10_2017\01-02_MRVC_Server_V8.lic:
mumdbsrv: license server UP (MASTER) v11.6
Vendor daemon status (on mumdbsrv):
RMCON: The desired vendor daemon is down.
Vendor:Host: mumdbsrv
License path: 27003@mumdbsrv;
available at "www.acresso.com".
Administrator Productivity
