Installation & Licensing
FLEXnet Licensing error:-97,121 after moving license server vm to new host
3 REPLIES 3
ThomasPickel
1570 Views, 3 Replies
Our ESX server failed and was replaced by a new one. I had a copy of the license server vm (2008R2) running FlexLM and moved that to the new ESX server. The license server vm is running fine, but FlexLM reports error -97,121.
The log file says
Wrong hostid on SERVER line for license file
  (path to license file)
SERVER line says 005056a7000b, hostid is 005056ae2eb8
What can I do to resolve this issue?
Thanks in advance!
Thomas
3 REPLIES 3
DarrenP
in reply to: ThomasPickel
the MAC address changed you need to generate a new license file or clone the MAC address from one VM to another
DarrenP
TravisNave
in reply to: DarrenP
Darren knocked this one out of the park.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
txheed
Or as long as there the old mac address doesn't exist within your network causing a duplicate nic then change it to the original mac used in config for your vm.
Administrator Productivity
