Our ESX server failed and was replaced by a new one. I had a copy of the license server vm (2008R2) running FlexLM and moved that to the new ESX server. The license server vm is running fine, but FlexLM reports error -97,121.
The log file says
Wrong hostid on SERVER line for license file (path to license file) SERVER line says 005056a7000b, hostid is 005056ae2eb8
What can I do to resolve this issue?
Thanks in advance!
Thomas
Solved by DarrenP. Go to Solution.
the MAC address changed you need to generate a new license file or clone the MAC address from one VM to another
DarrenP
Darren knocked this one out of the park.
Or as long as there the old mac address doesn't exist within your network causing a duplicate nic then change it to the original mac used in config for your vm.
