Installation & Licensing
FLEXnet Licensing error:-15,10
1 REPLY 1
21390 Views, 1 Reply
This is from Perform Status Enquiry
Status
Flexible License Manager status on Mon 7/4/2011 10:22
[Detecting lmgrd processes...]
License server status: 27000@mfg-PC
    License file(s) on mfg-PC: C:\Program Files\Autodesk\Autodesk Network License Manager\License File\mfg-PC.lic:
    mfg-PC: license server UP (MASTER) v11.9
Vendor daemon status (on mfg-PC):
  adskflex: Cannot connect to license server system.
The license server manager (lmgrd) has not been started yet,
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Server name:   192.168.188.129
License path:  27000@mfg-PC;
FLEXnet Licensing error:-15,10.  System Error: 10049 "WinSock: Invalid address"
From the debug log file
10:22:11 (adskflex) Vendor daemon can't talk to lmgrd (Cannot connect to license server system. (-15,10:10061 "WinSock: Connection refused"))
10:22:11 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
10:22:14 (lmgrd) adskflex exited with status 28 (Communications error)
10:22:14 (lmgrd) Since this is an unknown status, license server
10:22:14 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:22:14 (lmgrd) Starting vendor daemon at port 2080
10:22:14 (lmgrd) Using vendor daemon port 2080 specified in license file
10:22:14 (lmgrd) REStarted adskflex (pid 5908)
10:22:14 (adskflex) Unable to initialize access to trusted storage: 1
10:22:14 (adskflex) FLEXnet Licensing version v11.9.0.3 build 90785 x64_n6
10:22:15 (adskflex) Server started on mfg-PC for:
10:22:15 (adskflex) 85815PDSU_F (consisting of:                                85607SHOWCASE_2011_0F
10:22:15 (adskflex) 85545AMECH_PP_2011_0F 85503MAXDES_2011_0F 85579INVNTOR_2011_0F
10:22:15 (adskflex) 71800AMECH_PP_2010_0F 70000MAXDES_2010_0F 85577INVNTOR_2010_0F
10:22:15 (adskflex) 59200AMECH_PP_2009_0F 612003DSMAX_2009_0F 85796PDSU_2012_0F
10:22:15 (adskflex) 85615ALSK_2011_0F 85580MBXPRO_2011_0F 85000DESNST_2011_0F
10:22:15 (adskflex) 85567INVPRO_2011_0F 83900MBXPRO_2010_0F 70500INVPRO_2010_0F
10:22:15 (adskflex) 59600INVPRO_2009_0F 70200MBXPRO_2009_0F)
10:22:15 (adskflex) 85677FDSPRM_F (consisting of:                          85789FDSPRM_2012_0F
10:22:15 (adskflex) 85635FDSPRM_2011_0F 85561ARCHDESK_2011_0F 85607SHOWCASE_2011_0F
10:22:15 (adskflex) 85545AMECH_PP_2011_0F 85601NAVSIM_2011_0F 85503MAXDES_2011_0F
10:22:15 (adskflex) 85579INVNTOR_2011_0F 72200ARCHDESK_2010_0F 71800AMECH_PP_2010_0F
10:22:15 (adskflex) 71500NAVSIM_2010_0F 70000MAXDES_2010_0F 85577INVNTOR_2010_0F
10:22:15 (adskflex) 60100ARCHDESK_2009_0F 59200AMECH_PP_2009_0F 69000NAVSIM_2009_1F
10:22:15 (adskflex) 612003DSMAX_2009_0F 62800NAVSIM_2009_0F) 85753VLTM_2012_0F
10:22:15 (adskflex) PLIST
10:22:15 (adskflex) EXTERNAL FILTERS are OFF
10:22:16 (adskflex) Vendor daemon can't talk to lmgrd (Cannot connect to license server system. (-15,10:10061 "WinSock: Connection refused"))
10:22:16 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
10:22:19 (lmgrd) adskflex exited with status 28 (Communications error)
10:22:19 (lmgrd) Since this is an unknown status, license server
10:22:19 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:22:19 (lmgrd) Starting vendor daemon at port 2080
10:22:19 (lmgrd) Using vendor daemon port 2080 specified in license file
10:22:19 (lmgrd) REStarted adskflex (pid 252)
10:22:19 (adskflex) Unable to initialize access to trusted storage: 1
10:22:19 (adskflex) FLEXnet Licensing version v11.9.0.3 build 90785 x64_n6
10:22:21 (adskflex) Server started on mfg-PC for:
10:22:21 (adskflex) 85815PDSU_F (consisting of:                                85607SHOWCASE_2011_0F
10:22:21 (adskflex) 85545AMECH_PP_2011_0F 85503MAXDES_2011_0F 85579INVNTOR_2011_0F
10:22:21 (adskflex) 71800AMECH_PP_2010_0F 70000MAXDES_2010_0F 85577INVNTOR_2010_0F
10:22:21 (adskflex) 59200AMECH_PP_2009_0F 612003DSMAX_2009_0F 85796PDSU_2012_0F
10:22:21 (adskflex) 85615ALSK_2011_0F 85580MBXPRO_2011_0F 85000DESNST_2011_0F
10:22:21 (adskflex) 85567INVPRO_2011_0F 83900MBXPRO_2010_0F 70500INVPRO_2010_0F
10:22:21 (adskflex) 59600INVPRO_2009_0F 70200MBXPRO_2009_0F)
10:22:21 (adskflex) 85677FDSPRM_F (consisting of:                          85789FDSPRM_2012_0F
10:22:21 (adskflex) 85635FDSPRM_2011_0F 85561ARCHDESK_2011_0F 85607SHOWCASE_2011_0F
10:22:21 (adskflex) 85545AMECH_PP_2011_0F 85601NAVSIM_2011_0F 85503MAXDES_2011_0F
10:22:21 (adskflex) 85579INVNTOR_2011_0F 72200ARCHDESK_2010_0F 71800AMECH_PP_2010_0F
10:22:21 (adskflex) 71500NAVSIM_2010_0F 70000MAXDES_2010_0F 85577INVNTOR_2010_0F
10:22:21 (adskflex) 60100ARCHDESK_2009_0F 59200AMECH_PP_2009_0F 69000NAVSIM_2009_1F
10:22:21 (adskflex) 612003DSMAX_2009_0F 62800NAVSIM_2009_0F) 85753VLTM_2012_0F
10:22:21 (adskflex) PLIST
10:22:21 (adskflex) EXTERNAL FILTERS are OFF
10:22:23 (adskflex) Vendor daemon can't talk to lmgrd (Cannot connect to license server system. (-15,10:10061 "WinSock: Connection refused"))
10:22:23 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
10:22:24 (lmgrd) adskflex exited with status 28 (Communications error)
10:22:24 (lmgrd) Please correct problem and restart daemons
Actions Taken:
1.       Added ports TCP 2080, 2700, 27004 to my Windows Firewall
2.       Did the start/stop/reread of license file
3.       Restarted my system/machine
I still get the same error -15. Please help.
Thanks a lot,
Jerome
Tags (3)
1 REPLY 1
TravisNave
Looks as though your servername is mfg-PC.  Please make sure this is what is listed in the .lic file.  This file cannot be modified.  Your .lic file and computer information must match.
Your port numbers to open are 2080, 27000~27009, and also all 4 .exe NLM files are recommended as exceptions in your firewall.
For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
Autodesk Forums:
Administrator Productivity
