I noticed that you said redhat. FYI, it's not supported for Autodesk
licenses.
http://jtbworld.blogspot.com/2007/05/system-requirements-for-autodesk.html
http://jtbworld.blogspot.com/2007/08/autodesk-network-license-manager-on.html
Jimmy Bergmark
JTB World - Software development and consulting
Owner/Developer
http://www.jtbworld.com
JTB World offers you software's, custom software development, consulting...
http://www.jtbworld.com/about.htm
JTB FlexReport (FLEXnet / FLEXlm license report tool) -
www.jtbworld.com/jtbflexreport
AutoCAD 2008
http://www.jtbworld.com/autocad2008.htm
"moust222" wrote in message news:5709477@discussion.autodesk.com...
i trying to install the Flexlm 10.8 under redhat and i find that this error
appear
11:47:09 (lmgrd) The license server manager (lmgrd) running as root:
11:47:09 (lmgrd) This is a potential security problem
11:47:09 (lmgrd) and is not recommended.
license manager: can't initialize: Cannot find license file.
The license files (or license server system network addresses) attempted
are
listed below. Use LM_LICENSE_FILE to use a different license file,
or contact your software provider for a license file.
Filename: /Mentor/license.txt
License path: /Mentor/license.txt
FLEXnet Licensing error:-1,359. System Error: 2 "No such file or directory"
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com".
"1:47:09 (lmgrd) Using license file "/Mentor/license.txt
and i'm sure from the version and i redownload it and the same error appear
the license is worked under windows
but this happen specially in redhat
i checked the hostid and hostname
but i think the problem is in the Network configuration because i also
cannot see the local network
and one have a clear information about this problem
note
my system is redhat 4
