Installation & Licensing
New Member
Tahini
Message 1 of 6 (827 Views)
Flexnet License error -97,121
827 Views, 5 Replies
04-16-2013 05:35 PM
6 or more users suddenly could not obtain a license for AutoCAD today.
To my knowledge nothing had changed on the server or with the license file to cause this.
I checked the Hostname and ethernet address and they match what is in the license file.
I upgraded to the 11.11 version of FlexNet.
Not sure where else I should be looking.  Any help would be greatly appreciated!
Tanya
*Expert Elite*
DarrenP
Message 2 of 6 (823 Views)
Re: Flexnet License error -97,121
04-16-2013 05:55 PM in reply to: Tahini
can you run a status inquiry on flex lm?
Member
ankushvedautodesk
Message 3 of 6 (808 Views)
04-16-2013 08:22 PM in reply to: Tahini
Could you share your license file in a private message?
Employee
ankushved
Message 4 of 6 (803 Views)
04-16-2013 08:28 PM in reply to: Tahini
Thanks & Regards,
Ankush Ved
*Expert Elite*
TravisNave
Message 5 of 6 (781 Views)
04-17-2013 08:55 AM in reply to: Tahini
I suspect the 11.11 version of FlexLM.  Especially if you are using Server 2008 R2 or newer.
Try the 11.7 adskflex.exe vendor daemon file that I attached in a follow-up message in this thread:
http://forums.autodesk.com/t5/Installation-Licensing/Autodesk-Network-License-Manager-2014/m-p/38199...
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Valued Contributor
mohan_s
Message 6 of 6 (415 Views)
08-30-2013 02:55 AM in reply to: Tahini
Hi kindly refer the link given below were you will find all explanation of FLEXNET error codes, it might help you solve the issue. I encountered a same issue to one of my client and found that for some reason LMGRD excecutable was not loaded in to memory also at onother customers palce LMGRD was not present in the NLM program filder. In both cases i reinstalled application and added the NLM program folder in antivirus exclusion list with the subfolder options on.
Link
http://www.gtx.com/support/faqs/license/acresso/FLEXnet_Licensing_Error_Codes.asp
REgards
Mohan Suryawanshi-AE
Announcements
Need installation help?
