Since
FlexLM 10 and FlexLM 7 are separate instances, separate executables they
should work on the same machine.
size=3>
You may
want to lock the vendor daemon to a specific port per
face=Calibri color=#0000ff
size=3>http://support.esri.com/index.cfm?fa=knowledgebase.techarticles....
face=Calibri size=3> to avoid collisions with the AutoCAD vendor
daemon.
"Henrik Goldman" <
href="mailto:hg@x-formation.com">hg@x-formation.com> wrote in message
href="news:5703984@discussion.autodesk.com">news:5703984@discussion.autodesk.com...
> Is it possible to get both AutoCAD and ESRI
flex to coexist on one server? I
> don't even need it to be with the
same FLEX just on the same server. If so
> is there a white paper or
something to help me out? The dealer did not seem
> to
know.
This should be no problem. It's quite straight
forward to do this. Just install both... make sure they don't use the same
port numbers... query the server to see it works... and be happy
If you tell more where you got stuck we can
help you further.
size=+0>
