Installation & Licensing
New Member
0 Kudos
Post 1 of 3
FlexLM Error Message
8377 Views, 2 Replies
10-02-2009 12:38 PM
I have a Windows 2003 Server that I have the FlexLM service installed on. However, I get this error message in my logs when I attempt start the service. Obviously this is problematic because no licenses are being handed out. If you can check over my log file and give me a hand at resolving the problem I would greatly appreciate it.
Log File:
14:17:44 (lmgrd) -----------------------------------------------
14:17:44 (lmgrd) Please Note:
14:17:44 (lmgrd)
14:17:44 (lmgrd) This log is intended for debug purposes only.
14:17:44 (lmgrd) In order to capture accurate license
14:17:44 (lmgrd) usage data into an organized repository,
14:17:44 (lmgrd) please enable report logging. Use Macrovision's
14:17:44 (lmgrd) software license administration solution,
14:17:44 (lmgrd) FLEXnet Manager, to readily gain visibility
14:17:44 (lmgrd) into license usage data and to create
14:17:44 (lmgrd) insightful reports on critical information like
14:17:44 (lmgrd) license availability and usage. FLEXnet Manager
14:17:44 (lmgrd) can be fully automated to run these reports on
14:17:44 (lmgrd) schedule and can be used to track license
14:17:44 (lmgrd) servers and usage across a heterogeneous
14:17:44 (lmgrd) network of servers including Windows NT, Linux
14:17:44 (lmgrd) and UNIX. Contact Macrovision at
14:17:44 (lmgrd) www.macrovision.com for more details on how to
14:17:44 (lmgrd) obtain an evaluation copy of FLEXnet Manager
14:17:44 (lmgrd) for your enterprise.
14:17:44 (lmgrd)
14:17:44 (lmgrd)
14:17:44 (lmgrd)
14:17:44 (lmgrd) pid 1664
14:17:44 (lmgrd) Detecting other license server manager (lmgrd) processes...
14:17:44 (lmgrd) Done rereading
14:17:44 (lmgrd) FLEXnet Licensing (v11.5.0.5 build 60835 i86_n3) started on mhs-altiris2 (IBM PC) (10/2/2009)
14:17:44 (lmgrd) Copyright (c) 1988-2007 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
14:17:44 (lmgrd) US Patents 5,390,297 and 5,671,412.
14:17:44 (lmgrd) World Wide Web: http://www.macrovision.com
14:17:44 (lmgrd) License file(s): C:\Program Files\Autodesk Network License Manager\DES_ACA2010enlicense.lic
14:17:44 (lmgrd) lmgrd tcp-port 27000
14:17:44 (lmgrd) Starting vendor daemons ...
14:17:44 (lmgrd) Starting vendor daemon at port 2080
14:17:44 (lmgrd) Using vendor daemon port 2080 specified in license file
14:17:44 (lmgrd) Started adskflex (pid 3424)
14:17:44 (adskflex) Unable to initialize access to trusted storage: 1
14:17:44 (adskflex) FLEXnet Licensing version v11.5.0.0 build 56285 i86_n3
14:17:44 (adskflex) Server started on mhs-altiris2 for: 80200DES_ACA_2010_0F
14:17:44 (adskflex) EXTERNAL FILTERS are OFF
14:17:44 (lmgrd) adskflex using TCP-port 2080
14:17:46 (lmgrd) Rereading license file... Requested from da-mschmitt@mhs-altiris2
14:17:46 (adskflex) Failed to open socket to lmgrd, Exiting
14:17:46 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
14:17:46 (lmgrd) Can't send reread to adskflex: Cannot read data from license server system. (-16,10009:10054 "WinSock: Connection reset by peer")
14:17:46 (lmgrd) Done rereading
14:17:46 (lmgrd) ...Finished rereading
14:17:51 (lmgrd) adskflex exited with status 28 (Communications error)
14:17:51 (lmgrd) Since this is an unknown status, license server
14:17:51 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
14:17:51 (lmgrd) Starting vendor daemon at port 2080
14:17:51 (lmgrd) Using vendor daemon port 2080 specified in license file
14:17:51 (lmgrd) REStarted adskflex (pid 3440)
14:17:51 (adskflex) Unable to initialize access to trusted storage: 1
14:17:51 (adskflex) FLEXnet Licensing version v11.5.0.0 build 56285 i86_n3
14:17:51 (adskflex) Server started on mhs-altiris2 for: 80200DES_ACA_2010_0F
14:17:51 (adskflex) EXTERNAL FILTERS are OFF
14:17:51 (lmgrd) adskflex using TCP-port 2080
14:17:53 (adskflex) Failed to open socket to lmgrd, Exiting
14:17:53 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
14:17:56 (lmgrd) adskflex exited with status 28 (Communications error)
14:17:56 (lmgrd) Since this is an unknown status, license server
14:17:56 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
14:17:56 (lmgrd) Starting vendor daemon at port 2080
14:17:56 (lmgrd) Using vendor daemon port 2080 specified in license file
14:17:56 (lmgrd) REStarted adskflex (pid 3100)
14:17:56 (adskflex) Unable to initialize access to trusted storage: 1
14:17:56 (adskflex) FLEXnet Licensing version v11.5.0.0 build 56285 i86_n3
14:17:56 (adskflex) Server started on mhs-altiris2 for: 80200DES_ACA_2010_0F
14:17:56 (adskflex) EXTERNAL FILTERS are OFF
14:17:56 (lmgrd) adskflex using TCP-port 2080
14:17:59 (adskflex) Failed to open socket to lmgrd, Exiting
14:17:59 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
14:18:01 (lmgrd) adskflex exited with status 28 (Communications error)
14:18:01 (lmgrd) Since this is an unknown status, license server
14:18:01 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
14:18:01 (lmgrd) Starting vendor daemon at port 2080
14:18:01 (lmgrd) Using vendor daemon port 2080 specified in license file
14:18:01 (lmgrd) REStarted adskflex (pid 3532)
14:18:01 (adskflex) Unable to initialize access to trusted storage: 1
14:18:01 (adskflex) FLEXnet Licensing version v11.5.0.0 build 56285 i86_n3
14:18:01 (adskflex) Server started on mhs-altiris2 for: 80200DES_ACA_2010_0F
14:18:01 (adskflex) EXTERNAL FILTERS are OFF
14:18:01 (lmgrd) adskflex using TCP-port 2080
*Expert Elite*
903 Kudos
Post 2 of 3
Re: FlexLM Error Message
10-02-2009 12:43 PM in reply to: mschmitt79
Generally this error is caused by the Firewall or the Data Execution Prevention (DEP) interfering with the adskflex.exe. I would start by disabling any Windows or 3rd party firewall (or allow ports 2080 and 27000~27009) and add all four NLM files to the DEP exception list under System Properties.
Member
0 Kudos
Post 3 of 3
12-11-2009 08:12 AM in reply to: mschmitt79
1:01:59 (lmgrd) -----------------------------------------------
1:01:59 (lmgrd) Please Note:
1:01:59 (lmgrd)
1:01:59 (lmgrd) This log is intended for debug purposes only.
1:01:59 (lmgrd) In order to capture accurate license
1:01:59 (lmgrd) usage data into an organized repository,
1:01:59 (lmgrd) please enable report logging. Use Macrovision's
1:01:59 (lmgrd) software license administration solution,
1:01:59 (lmgrd) FLEXnet Manager, to readily gain visibility
1:01:59 (lmgrd) into license usage data and to create
1:01:59 (lmgrd) insightful reports on critical information like
1:01:59 (lmgrd) license availability and usage. FLEXnet Manager
1:01:59 (lmgrd) can be fully automated to run these reports on
1:01:59 (lmgrd) schedule and can be used to track license
1:01:59 (lmgrd) servers and usage across a heterogeneous
1:01:59 (lmgrd) network of servers including Windows NT, Linux
1:01:59 (lmgrd) and UNIX. Contact Macrovision at
1:01:59 (lmgrd) www.macrovision.com for more details on how to
1:01:59 (lmgrd) obtain an evaluation copy of FLEXnet Manager
1:01:59 (lmgrd) for your enterprise.
1:01:59 (lmgrd)
1:01:59 (lmgrd)
1:01:59 (lmgrd)
1:01:59 (lmgrd) pid 3032
1:01:59 (lmgrd) Detecting other license server manager (lmgrd) processes...
1:01:59 (lmgrd) Done rereading
1:01:59 (lmgrd) FLEXnet Licensing (v11.5.0.5 build 60835 i86_n3) started on tsawada-PC (IBM PC) (12/12/2009)
1:01:59 (lmgrd) Copyright (c) 1988-2007 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
1:01:59 (lmgrd) US Patents 5,390,297 and 5,671,412.
1:01:59 (lmgrd) World Wide Web: http://www.macrovision.com
1:01:59 (lmgrd) License file(s): C:\Program Files\Autodesk Network License Manager\License\license 001dba8cbe07\391-02907542.lic
1:01:59 (lmgrd) lmgrd tcp-port 27000
1:01:59 (lmgrd) Starting vendor daemons ...
1:01:59 (lmgrd) Starting vendor daemon at port 2080
1:01:59 (lmgrd) Using vendor daemon port 2080 specified in license file
1:01:59 (lmgrd) Started adskflex (pid 5112)
1:01:59 (adskflex) Unable to initialize access to trusted storage: 1
1:01:59 (adskflex) FLEXnet Licensing version v11.5.0.0 build 56285 i86_n3
1:01:59 (adskflex) Server started on tsawada-PC for: 70400INVBUN_2010_0F
1:01:59 (adskflex) EXTERNAL FILTERS are OFF
1:01:59 (lmgrd) adskflex using TCP-port 2080
1:02:04 (adskflex) TCP_NODELAY NOT enabled
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
