Installation & Licensing
FlexLM can't return license early
4 REPLIES 4
DRW_CAD
3448 Views, 4 Replies
This is a weird one. I have a guy who works out of town for long periods of time. He checked a license out & while it was out, I reinstalled the license manager in preperation for 2012 & now LM tools doesn't recognize that he has a license checked out so I can't check it back in & it's going to expire while he's out of town again. So what I want to do is either extend the current checked out license which I don't think you can do or return it early & check another one out. When I try to check it in, I get an error: 1.5-124, contact admin.
Any ideas?
4 REPLIES 4
TravisNave
in reply to: DRW_CAD
What you'll need to do is delete the borrowed license from the HKCU registry key.  I believe this is stored under HKCU\Software\FLEXlm License Manager\Borrow
You'll have to check. Always make sure to backup the registry before making changes.
After the borrowed license has been removed, you should be able to reborrow it.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
DarrenP
in reply to: TravisNave
here is the kb article: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10305068&linkID=9240617
DarrenP
DRW_CAD
in reply to: DarrenP
Much thanks, that did the trick.
TravisNave
Excellent. Glad you're up and running again.
Autodesk Forums:
Administrator Productivity
