Installation & Licensing
Member
0 Kudos
Post 1 of 13
FlexLM AC Electrical 2011 & PDSP 2014
295 Views, 12 Replies
10-03-2013 04:10 AM
Our license server servers licenses for both AutoCAD Electrical 2011 and Product Design Suite 2014. These products are reserved for 2 different sets of users. When users run AutoCAD Electrical, the license server wants to assign them a license for AutoCAD Electrical AND a license for Product Design Suite. They are not in the group for PDS so they don't have access to the PDS license. Since the PDS license is rejected, they are refused a license for AutoCAD Electrical. Is there a fix for this? An AutoCAD Electrical user should not be required to occupy 2 licenses, 1 for AC Electrical and 1 for PDS. I've attached my license file. Thanks.
you have to generate both the suite license and the autocad electrical 2011 license and the Autocad licenses at the same time
You can use the online method to activate your license here:
http://www.autodesk.com/licensesupport
Or you can can call Autodesk Product Registration and Authorization:
1-800-551-1490 > Option 1 (English) > Option 2 > (network)
Asia / Pacific: 65.6735.5688
Europe / Middle East / Asia: 41.32.723.9595
You will need to provide your serial number and theserver name, MAC Address
655 Kudos
Post 2 of 13
Re: FlexLM AC Electrical 2011 & PDSP 2014
10-03-2013 06:12 AM in reply to: borgertr
you need edit the file and take out serial numbers
this is a public forum don't post that kind of stuff on here
655 Kudos
Post 3 of 13
10-03-2013 06:15 AM in reply to: DarrenP
what does the flex lm log say?
can you post that?
655 Kudos
Post 4 of 13
10-03-2013 06:21 AM in reply to: DarrenP
what about the status inquiry?
Member
0 Kudos
Post 5 of 13
10-03-2013 07:01 AM in reply to: DarrenP
Sorry about the inappropriate attachment post.
I've attached the license.log file which has logged a single run of AutoCAD Electrical 2011. PDSP 2014 was not run in this log file.
Thanks.
655 Kudos
Post 6 of 13
10-03-2013 07:11 AM in reply to: borgertr
can you copy/paste the status inquiry also?
Member
0 Kudos
Post 7 of 13
10-03-2013 07:52 AM in reply to: DarrenP
Below is the output of a status enquiry. Not sure why the "License path" is showing the wrong port and server name. However, we were forced to change server names recently. But the "Server name" is showing the correct server IP address and it is handing out licenses correctly (except for this issue).
Status
Flexible License Manager status on Thu 10/3/2013 10:32
[Detecting lmgrd processes...]
Error getting status: Cannot connect to license server system.
 The license server manager (lmgrd) has not been started yet,
 the wrong port@host or license file is being used, or the
 port or hostname in the license file has been changed.
Server name:   <correct server IP address>
License path:  Flexlm for AutoDesk;<wrong port>@<wrong server name>;
FLEXnet Licensing error:-15,10.  System Error: 10061 "WinSock: Connection refused"
For further information, refer to the FLEXnet Licensing documentation,
available at "www.flexerasoftware.com".
655 Kudos
Post 8 of 13
10-03-2013 08:25 AM in reply to: borgertr
try editing the servername in the license file to the new name and try running status inquiry again
Member
0 Kudos
Post 9 of 13
10-03-2013 09:54 AM in reply to: DarrenP
The license file had the host name correct. It was the registry that had the bad information. So, the good status information is below.
I think this whole licensing problem stems from the fact that AutoCAD Electrical 2011 is listed under the PDSP 2014 "Package" statement in the license file. And, for some reason, the FLEXlm is combining the "stand alone" AutoCAD Electrical 2011 license with the PDSP 2014 license. And since the stand alone ACE 2011 users don't have permissions to use PDSP they don't get an ACE 2011 license.
Status
Flexible License Manager status on Thu 10/3/2013 12:24
License server status: 27001@<server name>
    License file(s) on <server name>: C:\FlexLM\AutoDesk\AutoDesk.lic:
<server name>: license server UP (MASTER) v11.11
Vendor daemon status (on <server name>):
  adskflex: UP v11.11
Feature usage info:
Users of 64300ACD_F:  (Total of 9 licenses issued;  Total of 1 license in use)
  "64300ACD_F" v1.000, vendor: adskflex
  floating license
    1085808091C <workstation name> <workstation name> (v1.000) (<server name>/27001 303), start Thu 10/3 10:01
Users of 51900AMECH_PP_2007_0F:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of 85538ACAD_E_2011_0F:  (Total of 2 licenses issued;  Total of 1 license in use)
  "85538ACAD_E_2011_0F" v1.000, vendor: adskflex
  floating license
    <user name> <workstation name> <workstation name> (v1.0) (<server name>/27001 601), start Thu 10/3 10:10
Users of 85814PDSP_F:  (Total of 2 licenses issued;  Total of 1 license in use)
  "85814PDSP_F" v1.000, vendor: adskflex
  floating license
    <user name> <workstation name> <workstation name> (v1.000) (<server name>/27001 501), start Thu 10/3 10:10
Users of PLIST:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of 86131PDSP_2014_0F:  (Total of 2 licenses issued;  Total of 0 licenses in use)
Users of 85962PDSP_2013_0F:  (Total of 2 licenses issued;  Total of 0 licenses in use)
Users of 86001INVPROSA_2013_0F:  (Total of 2 licenses issued;  Total of 0 licenses in use)
Users of 85795PDSP_2012_0F:  (Total of 2 licenses issued;  Total of 0 licenses in use)
Users of 85730ACD_2012_0F:  (Total of 2 licenses issued;  Total of 0 licenses in use)
Users of 85875ACDMAC_2012_0F:  (Total of 2 licenses issued;  Total of 0 licenses in use)
Users of 85678ACAD_E_2012_0F:  (Total of 2 licenses issued;  Total of 0 licenses in use)
Users of 85837NAVSIM_2012_0F:  (Total of 2 licenses issued;  Total of 0 licenses in use)
Users of 85762INVPRORS_2012_0F:  (Total of 2 licenses issued;  Total of 0 licenses in use)
Users of 85677ECSCAD_2012_0F:  (Total of 2 licenses issued;  Total of 0 licenses in use)
Users of 85846INVPROSA_2012_0F:  (Total of 2 licenses issued;  Total of 0 licenses in use)
Users of 85573INVBUN_2011_0F:  (Total of 2 licenses issued;  Total of 0 licenses in use)
Users of 85607SHOWCASE_2011_0F:  (Total of 2 licenses issued;  Total of 0 licenses in use)
Users of 85615ALSK_2011_0F:  (Total of 2 licenses issued;  Total of 0 licenses in use)
Users of 85580MBXPRO_2011_0F:  (Total of 2 licenses issued;  Total of 0 licenses in use)
Users of 85545AMECH_PP_2011_0F:  (Total of 2 licenses issued;  Total of 0 licenses in use)
Users of 85503MAXDES_2011_0F:  (Total of 2 licenses issued;  Total of 0 licenses in use)
Users of 85579INVNTOR_2011_0F:  (Total of 2 licenses issued;  Total of 0 licenses in use)
Users of 85536ACD_2011_0F:  (Total of 2 licenses issued;  Total of 0 licenses in use)
Users of 85601NAVSIM_2011_0F:  (Total of 2 licenses issued;  Total of 0 licenses in use)
Users of 85569INVPRORS_2011_0F:  (Total of 2 licenses issued;  Total of 0 licenses in use)
Users of 85581ECSCAD_2011_0F:  (Total of 2 licenses issued;  Total of 0 licenses in use)
Users of 85567INVPRO_2011_0F:  (Total of 2 licenses issued;  Total of 0 licenses in use)
Users of 85871ACD_2013_0F:  (Total of 9 licenses issued;  Total of 1 license in use)
  "85871ACD_2013_0F" v1.000, vendor: adskflex
  floating license
    1085808091C <workstation name> <workstation name> (v1.0) (<server name>/27001 403), start Thu 10/3 10:01
Users of 71200ACD_2010_0F:  (Total of 9 licenses issued;  Total of 0 licenses in use)
655 Kudos
Post 10 of 13
10-03-2013 10:09 AM in reply to: borgertr
the suite license is over riding the electrical 2011 license because they were generated at different times and the suite license was generated after the electrical license
so you should be seeing a total of 3 Autocad Electrical 2011 seats and not 2 this might be why your having errors
