Installation & Licensing
FlexLM 11.10. build 95001 x64 returns no license.
5 REPLIES 5
jonathan.quartier
1672 Views, 5 Replies
I have a 10-seat license and just got it verified with http://www.licenseparser.com.
The FlexLM runs as a service on a Win7 64 machine.
The clients are Win7 64 machines.
If I click Server Status it returns me this:
Status
Flexible License Manager status on Wed 1/16/2013 13:54
[Detecting lmgrd processes...]
License server status: 27000@XXXXX
    License file(s) on XXXXXX: C:\Program Files\Autodesk Network License Manager\lice\BDSADV2013enlicense.lic:
  XXXXXX: license server UP (MASTER) v11.10
Vendor daemon status (on XXXXXX):
  adskflex: UP v11.10
Feature usage info:
Users of 85788BDSADV_F:  (Total of 10 licenses issued;  Total of 0 licenses in use)
Users of 85948BDSADV_2013_0F:  (Total of 10 licenses issued;  Total of 0 licenses in use)
Users of 85788BDSADV_2012_0F:  (Total of 10 licenses issued;  Total of 0 licenses in use)
Users of 85778RSAPRO_2012_0F:  (Total of 10 licenses issued;  Total of 0 licenses in use)
Users of 85882INFMDR_2012_0F:  (Total of 10 licenses issued;  Total of 0 licenses in use)
Users of 85793REVSYP_2012_0F:  (Total of 10 licenses issued;  Total of 0 licenses in use) ...
 Server Diags:
Diagnostics
FLEXnet diagnostics on Wed 1/16/2013 13:53
License file: C:\Program Files\Autodesk Network License Manager\lice\BDSADV2013enlicense.lic
"85788BDSADV_F" v1.000, vendor: adskflex
  License server: XXXXXX
  floating license  starts: 1-jan-1990,  no expiration date
  Requests from the same USER/HOST do not consume a new license
This license cannot be checked out because:
A PACKAGE component must be specified.
Feature:       85788BDSADV_F
License path:  C:\Program Files\Autodesk Network License Manager\lice\BDSADV2013enlicense.lic;
FLEXnet Licensing error:-125,147
For further information, refer to the FLEXnet Licensing documentation,
available at "www.flexerasoftware.com".
"85948BDSADV_2013_0F" v1.000, vendor: adskflex
  License server: XXXXXXX
This license can be checked out
"85788BDSADV_2012_0F" v1.000, vendor: adskflex
And so on...
There I can only see one error. But accorting to http://forums.autodesk.com/t5/Installation-Licensing/FLEXnet-Licensing-error-125-147/td-p/2834003 it can be ignored.
Browsing to http://XXXXX:27000 gives me Wê-60Wê-60Wê-60Wê-60Wê-60
When I start ACAD it returns
A valid license could not be obtained by the network license manager.
Error [-15.570.0]
All these solutions from http://forums.autodesk.com/t5/Installation-Licensing/AutoCAD-2012-License-Error-15-570-0/m-p/3075606... did not work.
FLEXnet is the most frustrating software ever!
Any tricks/hints I should know?
TIA
Tags (1)
5 REPLIES 5
DarrenP
in reply to: jonathan.quartier
can the computer ping the license server by name?
DarrenP
jonathan.quartier
in reply to: DarrenP
Yes. The host answers....
DarrenP
how about on the license server
when you ping its self to you get an Ipv 4 address or a ipv6 address?
DarrenP
Darren is right, it has to be IPv4 and the correct one at that.
Also, note that Windows 7 has a concurrent connection limitation as well.  Depending on your version, you have a limitation of up to 20 concurrent sessions.  Server does not have this limitation.
For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
Autodesk Forums:
You did http://XXXXX:27000  but did you also do http://XXXXX:2080 ?  It might also be worth testing ports 27001 - 27009.  Basically the worstation needs to be able to communicate with the licence server through ports 2080 and 27000 - 27009.
I usually recommend doing a telnet to the server through those ports, however you would need to enable the telnet client on the workstation.
As has already been suggested is the IPV4/IPV issue
On the server if start the dos command prompt and do an ipconfig /all and see if you can find any lrefernce to IPV6 then you should either disable it
http://support.microsoft.com/kb/929852
OR
install the IPV6 version of LMTools
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10976858&linkID=13140816
Administrator Productivity
