I have been using Plant 3D with P&ID for several weeks. I now need to be able to work from home a few days a week. How would I be able to barrow the license?
Mark
type about in the command line
it should pop up the license info box and there should a borrow license button in that box
DarrenP
ThanksDarren.
Nowanew problem. I have attempted to installthe software on my PC at home. It gets to the end of installing & comes up saying failed.?
It doesn't give me a reason why. I have tried it entering the Ser # & Key and also as a 30 day trial. They both give me the same result. I need this at home because I will be working from home a few days a week.
Please help.
Mark
You cannot install a trial license and borrow a network license. You will need to install it as a network version with access to your NLM server first. Then you can borrow the license and take it home.
or if your on subscription you can request a home use license
DarrenP
So would I need to uninstall & re-install as a network installation?
I thought I could use the License Transfer Utility?
I thought this option was for those without a network install or without a network all together.
We have no network at out office. It's only my workstation that hase the Autodesk software on it.
I really need to get this resolved though.
True Autodesk rep?
Please get me an answer.
Thank you,
Mark
Your terminology led us to believe you had a network licensed copy. If you are using stand-alone, you can use the LTU, but you should instead ask for a home use license in this case.
Why don"t the error messages say what they really are? Wouldn"t that make all this a lot simpler? When I try to pull a license, it would be nice if it said "there aren"t any available " instead of some nonsesne about the server. I find this true with most of the error messages throughout the AD line.
